Determining Uncertainty in Position using Heinsburg's Uncertainty Principle
The discussion focuses on calculating the minimum uncertainty in the position of a ball using Heisenberg's Uncertainty Principle. The ball's mass is given as 52.9 g, moving at a speed of 12.2 m/s with a measurement accuracy of 0.04%. The user attempts to calculate the uncertainty in momentum (Δp) and subsequently uses it to find the uncertainty in position (Δx) through the equation Δx * Δp = ℏ/2. It is noted that using Planck's constant (ℏ) results in a very small value for Δx, indicating a minimal uncertainty in position. The conversation emphasizes the importance of unit conversion and accurate calculations in applying the principle correctly.
aquella7
A 52.9 g ball moves at 12.2 m/s.
If its speed is measured to an accuracy of
0.04%, what is the minimum uncertainty in
its position? Answer in units of m.
delta x times delta p = 1/2 (h/2pi)
I used the uncertainty of the speed to determine the minimum and maximum momentums for the ball. I used these to determine what delta p is equal to (0.6195648) and then substituted that number into the equation to solve for delta x. I used kilograms for the mass, which I believe are the correct units as opposed to just grams. If you could help me determine what I am doing wrong, that would be great! Thanks!
Welcome to PF.
Δp*Δx ≥ ℏ/2
Planck's constant is pretty small, so I'd think you should get a very small number here.
h = 6.6*10−34
And at that you are using ℏ which is h/2π.
Your Δp = .0004*.6344 already, so Δx must be quite small as far as the minimum allowed uncertainty in Δx
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
