Register to reply
Relation between mass and velocity
by sundar0206
Tags: mass, momentum, velocity
Share this thread:
sundar0206
#1
May13-09, 02:17 PM
P: 9
Hi fellas..
I am not so good with physics .. Clearly defined because I am a programmer... I came across this question during one of my simulation experiments .
I was using RK4 integrator to solve equations . Which means i feed in momentum to calculate the velocity.
Momentum = mass x velocity
I hope i did get that equation correctly. This meant that to find the velocity i multiple momentum with inverse mass. .
So for increasing the velocity of the particle u decrease the mass .. but is nt it a practical observation that a heavier object falls down faster...???? Am i wrong in saying this??? can someone tell me the physics behind it?
Phys.Org News Partner Physics news on Phys.org
A new, tunable device for spintronics
Watching the structure of glass under pressure
New imaging technique shows how cocaine shuts down blood flow in mouse brains
madmike159
#2
May13-09, 02:36 PM
PF Gold
madmike159's Avatar
P: 370
P = mv (momentum = mass x velocity). Mass doesn't change (so long a v is less than 10% of the speed of light). If v decreases then so will p. So momentum is proportional to velocity, with mass being the constant.
This should be fine unless your modling massless objects (light), or very fast objects (over 10% of the speed of light), in which case it gets more complex.
Bob S
#3
May13-09, 03:56 PM
P: 4,663
A complete relativistic relation is
E2 = (m c2)2 = (m0c2)2 + (pc)2
where pc = momentum in energy units (divide by c to get momentum) (note: the mass used in the momentum is the relativistic mass)
E = total energy
m = relativistic mass
m0 = rest mass
Example problem: If a moving neutral particle decays into two photons, a 500-MeV photon and a 600-MeV photon, with an opening angle of 60 degrees, what is the rest mass of the neutral perticle?
After balancing transverse momentum, the longitudinal momentum (pc units) is
pc = 600 cos(27 degrees) + 500 cos(33 degrees) = 953.94 MeV
E = 500 + 600 = 1100 MeV
Therefore
m0c2 = sqrt[11002 - 953.942] = 547.72 MeV
The closest particle is the eta meson, with a rest mass of 547.30 MeV.
The momentum beta of the neutral particle = 953.94/1100 = 0.8672
So velocity v = .8672 x 3 x 108 meters per sec = 2.599 x 108 meters per sec
sundar0206
#4
May13-09, 06:27 PM
P: 9
Thanks guys..
Think I understood... Thought mass to vary and wondered how the velocity would change relative to the varying mass. But ya.. silly of me.. mass doesnt change which makes my question a bit whacko obsolete.. and no my body doesnt travel to the speed of light so I guess I got my answer .. Thanks
Cantab Morgan
#5
May14-09, 08:08 PM
P: 261
Quote Quote by sundar0206 View Post
Actually, that is the opposite of an observation. It's a myth. If you drop two objects of different weights from the same height, you'll observe that they hit the ground at the same time. Heavier objects do not fall faster.
Amrit N
#6
May15-09, 07:47 PM
P: 23
Hey you refered that for increasing velocity , there is decreasing mass.This should be when momentum is suppose to be constant quantity, but actually it increases with increase in mass and velocity. i like to tell that its total quantity involved in motion.here mass and motion are part of quantities , if among two one increases, momentum increases
And other you told the heavier object fall faster,its wrong and note that all the boidies fall towards earth at 9.8m/s^2, they fall together
Bob S
#7
May15-09, 08:43 PM
P: 4,663
Here is the exact equation for relating particle relativistic total energy E, momentum p, and rest mass m0c2. I show here that for nonrelativistic particles, it reduces to the standard non-relativistic relation.
1) E2= (m0c2)2 + (pc)2
where E is total energy (rest mass + kinetic energy), m0c2 is rest mass, and pc is momentum in energy units (momentum x speed of light)
Using K as kinetic energy
2) E = m0c2 + K
3) (m0c2 + K)2= (m0c2)2 + (pc)2
4) (m0c2)2 + 2m0c2 K + K2 = (m0c2)2 + (pc)2
5) K (1+ K/2m0c2 )= (pc)2/2m0c2 = p2/2m0
For non relativistic cases, we drop the small term K/m0c2 and get the familiar equation:
6) K = p2/2m0 = m02 v2/2m0 = (1/2)m0v2 which is the non relativistic equation.
Register to reply
Related Discussions
Relation between velocity and force General Physics 7
Relation between Group velocity and Phase velocity Classical Physics 3
Velocity relation Introductory Physics Homework 16
A simple mass relation... High Energy, Nuclear, Particle Physics 1
Mass energy relation Introductory Physics Homework 3
