Euclidean Algorithm: Solving x-1 = (x^3-x^2+2x-2)-(x+1)(x^2-2x+1)
The discussion revolves around understanding a step in the application of the Euclidean algorithm, specifically regarding the equation x-1 = (x^3-x^2+2x-2)-(x+1)(x^2-2x+1). Participants are trying to clarify the reasoning behind the manipulation of terms and the identification of the greatest common divisor (gcd).
  • Participants are questioning the derivation of the term (x+1)(x^2-2x+1) and its relevance to the problem. There are inquiries about the underlying algebraic identities and the application of the extended Euclidean algorithm.
Some participants are exploring the algebraic proof of the identity presented, while others are attempting to connect the steps in the textbook to the current problem. There is an acknowledgment of the need for further explanation regarding the terms used in the equation.
There is mention of a potential misunderstanding regarding the definition of gcd and its relation to the last non-zero remainder found during the application of the Euclidean algorithm.
roam
The following is a worked example, I circled around the part which I couldn't follow:
http://img15.imageshack.us/img15/161/untitleou.jpg
To begin with, I can't understand why they wrote:
[tex]x-1 = \frac{1}{3}(x^3-x^2+2x-2)-\frac{1}{3}(x+1)(x^2-2x+1)[/tex]
(or [tex]3x-3 = (x^3-x^2+2x-2)-(x+1)(x^2-2x+1)[/tex])
What formula/theorem were they using here? I can't follow what is done here. :redface:
P.S. On the top it says [tex]gcd(2x^3+x^2-2x-1, x^3-x^2+2x-2)= x-1[/tex], but it previously said "the last non-zero remainder is a gcd". And when the Euclidean algorithem was applied we found that the last non-zero remainder is 3x-3 NOT x-1.
You're asking why it's true? Just use algebra to prove the identity!
You're asking why they knew it to be true? It's the middle line of the preceeding calculation.
You're asking why they thought it would help solve the problem? Presumably your textbook has explicitly presented a version of the extended Euclidean algorithm and is using that.
P.S. GCD's are only defined up to an invertible constant.
Why? Where did the [tex](x+1)(x^2-2x+1)[/tex] term come from?
I think I understand, but could you explain a bit more please?
It came from the middle line of the solution to the previous example. The textbook took the 1/3 out of (1/3x+1/3), placed it into (3x^2-6x+3), and ended up with (x+1)(x^2-2x+1).
  • · Replies 24 ·
