Wavelength limits of the Lyman and Paschen series of Hydrogen
In summary, to find the series wavelength limits of the Lyman and Paschen series of hydrogen using the Bohr theory, one can use the equation lambda = lambda limit (n2)/(n2-n02) where n0 = 1 for Lyman and n0 = 3 for Paschen. By taking the limit as n approaches infinity, the solutions are found to be 91.13 nm for Lyman and 820.1 nm for Paschen.
Jadehaan
24
Use the Bohr theory to find the series wavelength limits of the Lyman and Paschen series of hydrogen.
[tex]\lambda[/tex]=[tex]\lambda[/tex]limit(n2)/(n2-n02)
Lyman: n0=1
Paschen: n0=3
The solutions are 91.13 nm (Lyman) and 820.1 nm (Paschen) but I do not know the process of finding them.
Thanks for any help.
There's another equation relating the wavelength of an emitted photon to the quantum numbers [itex]n[/itex] and [itex]n_0[/itex]...use that equation and take the limit as [itex]n\to\infty[/itex] (why does this provide the limiting value of [itex]\lambda[/itex]?:wink: )
Followed your hint; got the answer. Much appreciation.
Thanks again,
Jim
Related to Wavelength limits of the Lyman and Paschen series of Hydrogen
What is the Lyman series of Hydrogen?
The Lyman series refers to the group of spectral lines emitted by Hydrogen atoms when electrons transition from higher energy levels to the n=1 energy level. These transitions result in the emission of ultraviolet (UV) light with wavelengths ranging from approximately 91 to 122 nanometers.
What is the Paschen series of Hydrogen?
The Paschen series is another group of spectral lines emitted by Hydrogen atoms when electrons transition from higher energy levels to the n=3 energy level. These transitions result in the emission of infrared (IR) light with wavelengths ranging from approximately 820 to 1875 nanometers.
What is the significance of the Lyman and Paschen series of Hydrogen?
The Lyman and Paschen series are important because they provide evidence for the quantization of energy in atoms. They also have applications in astronomy, as the detection of these spectral lines can provide information about the composition and temperature of celestial objects.
What are the wavelength limits of the Lyman and Paschen series?
The Lyman series has a lower limit of approximately 91 nanometers and an upper limit of 122 nanometers. The Paschen series has a lower limit of approximately 820 nanometers and an upper limit of 1875 nanometers.
Why are there only certain wavelengths in the Lyman and Paschen series?
The allowed wavelengths in the Lyman and Paschen series correspond to the energy differences between the energy levels in the Hydrogen atom. These energy differences are determined by the quantum mechanics of the atom, and only certain transitions are allowed. This results in the emission of specific wavelengths of light in the spectral lines of the Lyman and Paschen series.
