How Can Efficiency Be Maximized in a Velocity Compounded Impulse Steam Turbine?
To maximize efficiency in a velocity compounded impulse steam turbine, the project focuses on varying the steam's input mass flow rate to identify the optimal rate for maximum efficiency. The turbine's rated power is 820 kW, with specific mass flow rates at full and normal loads. A challenge arises due to the absence of a dynamometer to measure torque, prompting inquiries about alternative methods to determine output torque and power. Suggestions include measuring the air velocity driven by the shaft's blower and considering the performance curve of the blower for efficiency insights. Understanding the relationship between mass flow rate, RPM, and torque is crucial, as power output varies significantly with RPM changes.
paul89
hii frends,
im a doing a project on the efficiency improvement of a velocity compounded impulse steam turbine. we plan 2 do that by varying the input mass flow rate of steam and finding out the particular mass flow rate at which maximum efficiency is attained.
the data i could collect were: rated power of turbine = 820 kw
speed at full load = 5000 rpm
mass flow rate at full load = 11.3 tn/hr
speed at normal load = 3000 rpm
mass flow rate at normal load= 8.1 tn/hr
to find out the efficiency u need to find out the output shaft power 4 tat mass flow rate
the formula for output shaft power is = (2*3.14*N*T)/60000 KW
but the problem is tat turbine is not fitted with any device(eg dynamometer) 2 find out the torque at the shaft
is there any other method 2 find out the output torque developed on the turbine shaft?
are there any other formulas 2 find out the output power corresponding 2 the input mass flow given?
or are there any other suggestions 2 find out the max efficiency point. pls suggest
shaft is driving a blower
So why don't you measure the velocity of the air? Do you have a performance curve for the blower (ie, to tell you the efficiency)?
Note, your power output will vary as a cube function of rpm, so you'll want to be careful to make sure you understand what you are measuring. When you vary your mass flow rate, you'll vary your rpm, which will have a huge impact on the torque. I would think either a constant rpm or constant torque scenario would be desirable for this.
thanks russ. ill try tat
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
