How would i measure the frequency, of a song, or sounds?
  • Thread starter Thread starter Senjai
    Frequency Measure
To measure the frequency of music, a microphone is needed to capture the sound, followed by software capable of performing a Fourier transform on the audio data, such as Goldwave. The Fourier transform reveals both the pitch frequencies and the lower frequencies related to the beat. It's important to clarify the specific patterns of interest, whether they relate to historical musical structures or specific melodic and harmonic patterns. Understanding these distinctions can guide the analysis effectively. Exploring these geometric patterns in music over time can yield fascinating insights into musical evolution.
Senjai
Just curious, what would be a means of measuring various frequencies of music?
Obviously you would require a microphone, and then what? Would you need a specific type of software? What are the types of physics that would be involved...
Would anyone be able to refer me to some notes or explinations?
I want to look at certain geometric patterns in music over history.
Regards,
Senjai
for signal analysis, you will need:
1) the music as a data-file in waveform (pressure vs. time)
2) Any software that can Fourier transform the data (Goldwave is one I know of that has a free version)
You also have to think about what you're asking. The Fourier transform will show the higher frequencies that correspond with the pitches (the notes played) but it will also have low frequencies that correspond to the beat of the music and have nothing to do with the pitch.
For instance, if you play a middle A four times with 6 seconds in between, your Fourier transform will show a peak for the 10 Hz signal from the beat, but also a peak for the 440 Hz signal from the pitch of the note).
I'm interested in what "patterns" you are looking for. Are you talking about the patterns mentioned by pythagorean above, or are you more concerned with the patterns in the melody or harmony? I ask as you mention "over history" and wondered what this actually involves.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
