Understanding the Derivative of sin^2x: Common Mistakes and Clarifications
  • Thread starter Nerd
  • Tags
    Derivative
In summary, the discussion is about the difference between the derivative of two functions and how it can be different.
Nerd
Hi.
Please tell me where this reasoning is wrong, because I know it is but I can't see how.
f(x) = sinx
f ' (x) = cosx
f(60) = sin 60
f ' (60) = cos 60
but
g(x) = sin 2x
g'(x) = 2 cos 2x
set x = 30
then: g(30) = sin 60
g'(x) = 2 cos 60
but
f(60) = g(30)
so f ' (60) = g'(30)
i.e cos 60 = 2 cos 60
thus: 1 = 2
WHY! HOW!
The fact that two functions cross at a particular point does not mean that their derivative is the same.
You could do the same thing with much simpler functions eg f(x)=x, g(x)=2x these cross at x=0 but they obviously don't have the same gradient.
Thank you. That is quite obvious, isn't it.
Try this one:
x=0
x+1=1
(x+1)(x+1)=1(x+1)
x^2+2x+1=x+1
x^2+x=0
x(x+1)=0
x+1=0
x=-1
darkside00 said:
Try this one:
x=0
x+1=1
(x+1)(x+1)=1(x+1)
x^2+2x+1=x+1
x^2+x=0
x(x+1)=0
x+1=0
x=-1
:wink: Ops!
Where did it go wrong algebraically?
I just told you! I boldfaced those parts.
Actually, you could just as easily say that at...
x(x+1) = 0
You could just as easily divide by (x+1) to get...
x = 0.
After all, the first equation in this post says that x is EITHER 0 or -1.
And we know that it's zero.
x(x+1) = 0
x = 0.
If you do that you might miss out a solution.
if ab=0, then either a=0 or b=0.
if you just divide by a, you'll get b=0 only.
^What he said. Doing that causes a missing solution. By the end, you should get x= -1 or 0. However, -1 is an extraneous solution. Therefore, you're stuck with x=0. Check out http://en.wikipedia.org/wiki/Extraneous_solution if you're confused.
Yeah, I know that...
My point was that he missed a solution.
Moderator's note:
Please keep on topic with the thread. New topics should be started in a new thread.
(See post #1 if you don't know what the topic of this thread is.)
Related to Understanding the Derivative of sin^2x: Common Mistakes and Clarifications
1. What is the derivative of sin^2x?
The derivative of sin^2x is 2sinxcosx.
2. How do you derive the formula for the derivative of sin^2x?
The formula for the derivative of sin^2x can be derived using the chain rule and the power rule. First, we rewrite sin^2x as (sinx)^2. Then, we apply the chain rule by multiplying the derivative of the outer function (2x) by the derivative of the inner function (sinx). This gives us 2sinxcosx.
3. What is a common mistake made when finding the derivative of sin^2x?
A common mistake is forgetting to use the chain rule when taking the derivative of sin^2x. It is important to remember that the power rule only applies to functions of the form x^n, so the chain rule must be used when the power is a function of x (in this case, sinx).
4. Can the derivative of sin^2x be simplified further?
Yes, the derivative of sin^2x, 2sinxcosx, can be simplified further using trigonometric identities. It can be rewritten as sin2x, which is equivalent to 2sinxcosx.
5. How does understanding the derivative of sin^2x relate to real-world applications?
The derivative of sin^2x is an important concept in calculus and is used in many real-world applications, such as physics, engineering, and economics. It can be used to analyze the rate of change of a system or to optimize functions. For example, in physics, it can be used to calculate the velocity of a moving object or the acceleration of a falling object.
