Solving trigonometric equation
To solve the trigonometric equation starting from sin C = 2/√29, the key is recognizing that C = 1/2 sin^(-1)(20/29) is equivalent to sin(2C) = 20/29. This relationship allows for the transformation of the equation into a more manageable form. The hints provided emphasize the connection between the sine function and its inverse. The discussion concludes with the participant confirming their understanding of the solution.
thereddevils
This is part of the identity proving question .
from \sin C=\frac{2}{\sqrt{29}} , how can i reach C=\frac{1}{2}\sin^{-1} (\frac{20}{29}) ?
Hi thereddevils! :smile:
(have a square-root: √ and try using the X2 tag just above the Reply box :wink:)
Hint: C = 1/2 sin-1 20/29 is the same as sin2C = 20/29 :wink:
got it thanks !
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
