Derivations of Euler equations
The discussion centers on the relationship between variations and derivatives in the context of Euler equations, specifically the equation δ∂(x) = ∂δ(x). It is clarified that δ represents an operation rather than a variable, suggesting a commutative property between the variation and the derivative. The conversation explores how changing a function f(x) by an infinitesimal amount leads to the conclusion that δ(∂f(x)/∂x) equals ∂(δf(x))/∂x. A rigorous argument is proposed using the chain rule and first-order Taylor expansion to justify neglecting higher-order terms. Ultimately, the discussion emphasizes the need for precision in mathematical expressions involving variations and derivatives.
zwoodrow
Every textbook i find breezes over the following point:
\delta\partial (x) =\partial \delta (x)
where delta is just the variation. Someone asked me why that's true and i guessed the only thing i could say was that delta is an operation not a variable so this is more like an algebraric statement of the commutivity of delta and taking a derivative. Is this right or is there a more clear explanation.
I always view it as follows.
What we do, is changing some function f(x) by an infinitesimal amount, i.e. replace
f(x) \to f(x) + \delta f(x) \qquad\qquad(*)
(and ignore higher order variations).
So in this notation, where delta indicates the infinitesimal change, it should also be true that
\frac{\partial f(x)}{\partial x} \to \frac{\partial f(x)}{\partial x} + \delta \left(\frac{\partial f(x)}{\partial x} \right)
(which is just statement (*) again for another function g(x) = df(x)/dx).
Now if you differentiate (*) you get an equation from which it follows immediately that
\delta \left(\frac{\partial f(x)}{\partial x} \right) = \frac{\partial(\delta f(x))}{\partial x}
Is there a way to argue that (using the chain rule)
\partial(\deltaf(x) ) = f(x)\partial\delta + \delta\partialf(x)
and then argue that\partial\delta is a second order differential that can be tossed out as approx 0 giving the result
\partial(\deltaf(x) ) = [STRIKE]f(x)\partial\delta[/STRIKE] \rightarrow 0 + \delta\partialf(x)
Not if you want to be rigorous.
Because \delta in itself doesn't mean anything, just like \partial doesn't mean anything.
The object you are looking at is \delta f(x).
If you want to be precise, you can use a first order Taylor expansion
f(x) \to F(x) = f(a) + f'(a) (x - a) + \mathcal{O}((x - a)^2)
where you call \delta = f'(a) (x - a) and neglect the quadratic terms.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
