How is Kinetic Energy Conserved in an Elastic Collision?
fizziksr0cks
A 8.5 kg steel ball, traveling left to right at 12 m/s, undergoes an elastic collision with a 5 kg steel ball at rest. To the nearest Joule, what is the Total Kinetic Energy of the two balls after collision? If the first ball has a mass of 10 kg and the second ball is traveling at it with a speed of 3 m/s, what is the velocity, to one decimal place, of the first ball after collision? What is the velocity of the second ball to one decimal place?
1/2mvi2+1/2mvii2=KE
Question 1:
1/2 (8.5)(122)= 612 J
Question 2 & 3:
I'm not sure the equation needed to solve for the needed. I'm pretty sure that if I can get question 2 then the same method will be used to solve question 3.
For questions 2 and 3 you need to conserve momentum in addition to energy conservation.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
