Free expansion and adiabatic process
In an adiabatic process, the change in entropy (ΔS) is zero because heat transfer (Q) is absent. However, in a free expansion, although both work (W) and heat (Q) are zero, the process is irreversible, leading to a non-zero change in entropy. The formula for ΔS is only applicable to reversible processes, which is why ΔS cannot be zero for free expansion. To accurately calculate the entropy change in free expansion, one must connect the initial and final states through a reversible path. This distinction clarifies the misunderstanding regarding the application of the entropy formula in different types of processes.
sita1
I hope someone in here can help me out of this problem.
I know that for calculating the change in entropy of a system (\Delta S) we can use this formula :
\Delta S=\intδq/T
Well the problem is here, when we calculating ΔS for an adiabatic process we know Q= 0 so ΔS=0 in this process, but why we just can't let Q be equal to zero in a free expansion (while we know that in free expansion W=Q=0) and get to the same result (ΔS=0) for the free expansion process?
I should add that I know ΔS≠ 0 for free expansion process but, you know I just don't know where the problem is in my argument.
The formula you wrote is only valid for a reversible process. And the free expansion is not a reversible process. To calculate the difference in entropy in this case, connect the initial and final state by any reversible path, for which generally you won't have dQ = dL = 0, and use your formula on this path.
Thanks, that's really a convincing answer.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
