Thread Closed
Fraunhofer Diffraction Proving
Share Thread Thread Tools
Sep15-04, 02:53 AM   #1
I am to prove that in
y = R * m * (wavelength) / a
where y is the distance between two minima, a is the width of the slit, R is the length between the screen and the slit grating, and m is an integer which is the order of the minima.
I know I have to use the paraxial approximation where tan x is approximately sin x which is approx. x, but I can't seem to apply it. When I refer to my textbooks, they state that y is the difference between the central maximum and the first minimum when m=1. Is this applicable bet. two minima as well?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Sep15-04, 07:20 PM   #2
Recognitions:
Start with the condition for constructive interferance;
dsin(theta) = m(lambda)
Then apply the small angle approximation. It is quite simple.
Your textbook is referring to y as the difference between the first maximum and the centre of the pattern, which is equivalent (within the small angle approximation) to the distance between successive minima.
Claude.
Thread Closed
Thread Tools
Similar Threads for: Fraunhofer Diffraction Proving
Thread Forum Replies
fraunhofer intensity pattern Advanced Physics Homework 0
Fraunhofer diffraction General Physics 3
Incidence angle in a Fraunhofer single slit problem Introductory Physics Homework 3
fraunhofer diffraction Advanced Physics Homework 0
