Why am I getting Vout = Vsupply in my op amp circuit?
  • Thread starter Thread starter ponjavic
    Amp Op amp
The discussion centers on troubleshooting an op-amp circuit where the output voltage (Vout) equals the supply voltage (Vsupply) regardless of the input voltage (Vin). Users are advised to ensure correct pin connections of the op-amp, check the integrity of the op-amp chip, and verify resistor values with a digital voltmeter (DVM). Additionally, the circuit's design is clarified, indicating that a dual voltage power supply is assumed, and modifications are suggested for using a single power supply to achieve the desired output behavior.
  • Understanding of op-amp configurations, specifically non-inverting amplifiers
  • Familiarity with voltage supply requirements for op-amps
  • Knowledge of resistor values and their impact on circuit behavior
  • Ability to use a digital voltmeter (DVM) for resistance and voltage measurements
  • Research modifications for single-supply op-amp circuits
  • Learn about op-amp pin configurations and their significance
  • Explore troubleshooting techniques for op-amp circuits
  • Study the effects of resistor values on gain in op-amp applications
Electronics enthusiasts, circuit designers, and engineers working with op-amp configurations who need to troubleshoot and optimize their amplifier circuits.
ponjavic
Hi!
I solder the following circuit:
http://en.wikipedia.org/wiki/File:Op-Amp_Non-Inverting_Amplifier.svg
With an opamp of +-5V or 0-10V operation
I use a 12V dc supply and give a Vin of 0.05V with resistors 10k and 1k.
For all cases no matter what I supply I get Vout = Vsupply.
Then we stripped everything nad just tried to supply v- and v+ 1.0001 and 1.0002 and still got Vout = Vsupply
Any ideas?
ponjavic said:
Hi!
Any ideas?
Stay with the +/-5V supplies for now. When you put in 0V, you should get out 0v.
If you don't, double-check the pinout of the opamp to be sure you are connecting it correctly. Try a 2nd opamp chip in case the first one is blown. You do have the opamp chip socketed, right?
Double-check the resistances with a DVM. Maybe the resistors are not what you think, or are damaged. Check the resistances with the power off.
ponjavic said:
Hi!
For all cases no matter what I supply I get Vout = Vsupply.Then we stripped everything nad just tried to supply v- and v+ 1.0001 and 1.0002 and still got Vout = Vsupply
Any ideas?
The circuit in Wikipedia assumes a dual voltage power supply.
If you want to use one power supply, you need to do this:
[PLAIN]http://dl.dropbox.com/u/4222062/opamp%20non%20inv%20bias.PNG
This will have a gain of 9 but centred around 6 volts.
So, 6 volts in gives 6 volts out.
6.1 volts in gives (6 V + (9 * 0.1)) or 6.9 volts out.
6.5 volts in gives (6 V + (9 * 0.5)) or 10.5 volts out.
5.8 volts in gives (6 volts - (9 * 0.2)) or 4.2 volts out.
  • · Replies 20 ·
