New Reply
Stored Magnetic Energy - Inductor Circuit
Share Thread Thread Tools
Mar28-11, 12:09 PM   #1
In the above circuit, the EMF from the battery is 12 V and the resistor has a resistance is 6.6 Ω. The inductor consists of a long, thin cylindrical coil of wire with 30000 turns, a radius of 5 cm and a length of 61 cm.
Answer the following questions for a time 1.4 seconds after the battery has been connected.
(c) How much energy has been delivered by the battery up to this point?
2. Relevant equations
U = 0.5LI^2
∫Udt from 0 to 1.4s
3. The attempt at a solution
I found the inductance and the current for the 1st two parts of the problem:
(a) What is the inductance of the solenoid? 14.56171141 H
(b) What is the current through the battery? 0.8542201 A
I plugged in the numbers to find the energy: U =0.5*14.56171141*(0.8542201^2) = 10.62556402 J
Then I think that you would have to integrate over time from 0 to 1.4s which gave me a result of 7.4378948 J.
It did not like the answer. Any suggestions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar28-11, 12:34 PM   #2
you know the eqn of current in circuit at some time t
use it to find the charge flown through battery ... q = ∫i dt
where t changes from 0 to 1.4
now work done by battery = Q(EMF) = energy delivered
Mar29-11, 07:52 AM   #3
Do I just inetrate (V/R)*(1-e^(Rt/L))? Its the only thing i can think of now that will be of any help. I tried to figure this one out from the hints you gave me but no luck.
Mar29-11, 08:27 AM   #4
Recognitions:
Homework Helper Homework Help
Quote by Bryon View Post
You have the expression for the current with respect to time. That's the current that is being delivered by the battery to the circuit. Do you know what the instantaneous power (watts) delivered by the battery is?
Mar29-11, 08:39 AM   #5
Yes, it is P=V*I(t). So, when I find the total current over time I can just plug it in to that!
Mar29-11, 08:54 AM   #6
Recognitions:
Yup. Integrate the power to find the total energy delivered.
Mar29-11, 08:58 AM   #7
Quote by gneill View Post
But same is integrate current and then multiply by V
both methods seems different but are same, right?
Mar29-11, 09:01 AM   #8
Thanks for the help! I see if i can get it in a bit!
Mar29-11, 09:02 AM   #9
Recognitions:
Yes; in this case the voltage is constant, so it can be "pulled out of" the integral.
New Reply
Thread Tools
Similar Threads for: Stored Magnetic Energy - Inductor Circuit
Thread Forum Replies
The energy stored in an inductor Electrical Engineering 6
Energy Stored In a Magnetic Coupled Circuit Engineering, Comp Sci, & Technology Homework 0
energy stored in an inductor Introductory Physics Homework 7
How much of this energy is stored in the magnetic field of the inductor? Introductory Physics Homework 2
Magnetic field stored in an inductor? Classical Physics 0
