Initial Velocity of Charged Particle in Electric/Magnetic Fields
The discussion revolves around determining the initial velocity components of a charged particle moving through electric and magnetic fields. The problem involves a negatively charged particle in a specified electric field and magnetic field, with a net force acting on it. Participants explore the relationships between force, charge, and velocity in the context of electromagnetism.
  • Participants discuss the calculations of forces due to electric and magnetic fields, questioning the directions of these forces and their implications for the particle's velocity. There is an exploration of the right-hand rule and the significance of signs in the calculations. Some participants express uncertainty about the setup and the relationships between the forces involved.
There is an ongoing exploration of the problem, with participants providing insights into the correct application of physical principles. Some guidance has been offered regarding the direction of the velocity and the importance of correctly interpreting the forces acting on the particle. Participants are actively engaging with the problem, and there is a recognition of mistakes made in earlier calculations.
Participants note the importance of understanding the signs in calculations and the implications of the particle's charge on its motion. There is a mention of the need to clarify assumptions about the directions of forces and velocities in the context of the problem.
Weistber
Hello all,
I got this question off mastering physics and was unable to understand it. I eventually gave up to concentrate on other assignments and asked for the answer. I was unable to come up with more than one answer I thought possible without resorting to trial and error.
Answer: Vx,Vy,Vz = 0,-234,0 m/s
A 6.50 negative microC particle moves through a region of space where an electric field of magnitude 1200 N/C points in the positive x direction, and a magnetic field of magnitude 1.02 T points in the positive z direction.
If the net force acting on the particle is 6.25×10−3 N in the positive x direction, find the components of the particle's velocity. Assume the particle's velocity is in the x-y plane.
Vx = ? Vy =? Vz = ?
Force = electric field * charge
or F=e*q
Force = magnitude of charge * velocity * magnetic field * sin tither
or F=|q|*v*B*sin tither
Force on particle due to Electric Field = E*q
= (1200N/C)(-6.5*10-3 C)
= -7.8*10-3N
Force on charge due to magnetic field = |q|*v*B*sin tither
= (6.5*10-6 C)(1.02T)(v)(sin 90)
= (6.63*10-6)(v)
Fx1 along x-axis = -7.8*103N
I'm sure the force on charge due to magnetic field lies between axis of positive Y and axis of negative X. The force on the particle needs to be perpendicular to the positive z direction of the magnetic field and the velocity of the particle which is one the x-y plane. Since the net force is in the x-direction, it should be along the x-axis. This was also the reasoning that led me to using sin90 when determining the force on the charge due to the magnetic field.
Fx2 along x-axis = (6.63*10-6)(v)
At this point, I thought I understood the problem statement fully. I took the net force from these two vectors I had come up with and separated velocity to LHS and the constants to the right.
Vx= (Net Force x + Fx1) / (Fx2 without velocity term)
= ((6.25×10−3 )+(7.8*103)) / (6.63*10-6)
= 2.12*107 m/s
The value was ridiculously large and I was not surprised it was rejected by mastering physics. I think I have a huge misunderstanding of the concept or method behind this question. Please explain to me how I should go about dealing with a question of this type or point out my mistakes. I do not need a worked out solution, coming up with that myself would probably be better for me.
Thank you
= -7.8*10-3N
Answer is correct, along the x axis. So the force is in the -x direction. Charge is -6.5*10-6 C. - check typo.
= (6.63*10-6)(v)Fx1 along x-axis = -7.8*103N
But which direction along the x axis? Positive or negative? Since the net force is in the positive direction and the magnitude of the Coulomb force is negative, this force must be in the positive x direction - ie. opposite to the Coulomb force.
To find the direction of v then, apply the cross-product (right-hand) rule.
= 2.12*107 m/s
You understand the problem. You just have to keep a few things straight. You have to determine the direction of v first and that will help you solve the problem. Be careful with the numbers. You are forgetting the - sign in some of the powers.
I suggest you work out the direction of v from the physics to avoid being confused by all the + and - signs. Also, it is better to work out the solution algebraically and then plug in numbers.
AM
Thank you for the swift and verbose response. I'll work through the question again and pay attention to the signs and powers. I apologise, this was obviously sloppy work on my part.
Thank you, I got the answer. Here is how I got it.
Force on particle due to electric field:
Fx1 = E*q
= (1200N/C)(-6.5*10-6)
= -7.8*10-3
Force on particle due to magnetic field:
Fx2 = |q|*v*B*sin tither
= (6.5*10-6)(1.02)(sin90)v
= (6.63*10-6)(v)
Fx2 is in the positive x direction as Fx1 is in the negative x direction while net force is in the positive x direction.
My first mistake was in the direction of the particle's velocity, I'm now more familiar with the right hand rule.
Magnetic field is in the positive Z direction, net force is in the positive x direction. According to right hand rule, Force acting on particle is perpendicular to the direction of magnetic field and velocity of particle.
This would mean the force is along the y-axis. As this is a negatively charged particle, the direction of the velocity of the particle is reversed. Therefore velocity of particle, v, has to be in the negative y direction.
My second mistake was my sign of Fx1 used to determine the value of velocity. I added Fxnet to Fx1 instead of subtracting Fxnet by Fx1.
Fxnet - Fx1 = Fx2
(6.25*10-3) - (7.8*10-3) = (6.63*10-6)(v)
v = (Fxnet - Fx1) / (Fx2 /v)
= ((6.25*10-3) - (7.8*10-3)) / (6.63*10-6)
= (-233.7) m/s
vy = -234 m/s
Thank you very much for your help, I'm glad I learned something instead of just walking away from mastering physics without any idea.
Good job. To do physics you have to persevere. If you master perseverance, you are be half-way there. And by perseverance I don't mean just plodding along until you get the right answer. I mean working at it until you really understand what is going on. Good luck!
AM
  • · Replies 31 ·
  • · Replies 25 ·
  • · Replies 18 ·
