| New Reply |
comparison of width of a wavefunction in real space and momentum space |
Share Thread | Thread Tools |
| Oct13-11, 01:57 PM | #1 |
Hello, I have a slight problem with Quantumtheory here.
1. The problem statement, all variables and given/known data I have solved the schrödinger equation in the momentum space for a delta potential and also transfered it into real space. So now I have to find the correlation between the width of the wavefunction in both spaces (and then motivate it physically) and I am stuck here because I don't even know where to start. 2. Relevant equations [itex]\Psi (x) = \sqrt{\kappa}e^{- \kappa |x|}[/itex] [itex]\Psi (p) = \frac{\sqrt{2 ( \hbar \kappa)^3}}{\sqrt{\pi}(p^2 + (\hbar \kappa)^2)}[/itex] 3. The attempt at a solution I was thinking about maybe the uncertainty relation of momentum and space would help here, but I am stuck where to start. Hope someone can help or give a hint. |
| Oct13-11, 04:02 PM | #2 |
Just looking at the functions, you can approximate the characteristic width of the wave functions in position space by using [itex]\kappa x \approx 1[/itex] and in momentum space by using [itex]p / \hbar \kappa \approx 1[/itex].
If you want to be more precise, calculate [itex]\Delta x = \sqrt{\langle x^2 \rangle - \langle x \rangle^2}[/itex] and [itex]\Delta p = \sqrt{\langle p^2 \rangle - \langle p \rangle^2}[/itex]. |
| Oct13-11, 04:47 PM | #3 |
Thanks I will look into it. I guess I have to calculate Δx and Δp since I need a correlation how the width in momentum space affects the width in real space and vice versa.
| New Reply |
| Thread Tools | |
Similar Threads for: comparison of width of a wavefunction in real space and momentum space
| Energy band in K space VS real space | Atomic, Solid State, Comp. Physics | 3 | ||
| Momentum/Real space | Advanced Physics Homework | 1 | ||
| How to switch between momentum/real space | Quantum Physics | 1 | ||
| Transformation of energy space to momentum space | Quantum Physics | 2 | ||
| band diagram in real space vs reciprocal space | Atomic, Solid State, Comp. Physics | 3 | ||
