| New Reply |
Positive Definiteness of a Real Matrix |
Share Thread |
| Nov17-11, 03:56 PM | #1 |
Decide for or against the positive definiteness of [2 -1 -1 -1 2 -1 = A -1 -1 2] [2 -1 -1 -1 2 1 = B -1 1 2] [5 2 1 2 2 2 = C 1 2 5] 2. Relevant equations Each of the following tests is a necessary and sufficient condition for the real symmetric matrix A to be positive definite: a) xTAx greater than 0 for all nonzero real vectors x. b) All the eigenvalues of A are greater than 0 c) All the upper left submatrices of A have positive determinants d) All the pivots (without row exchanges) are greater than 0. 3. The attempt at a solution For matrix A, I found that it fails tests b,c and d. I'm a bit confused because when I performed test a with vector x = [ 1 2 3 ] ^T the test passes, but with an x = [1 1 1]^T the test fails. Therefore, I said that it is not positive definite, but I'm unsure on this one. For matrices B and C, I said that they are both positive definite because they both pass test c. I'm assuming that if it passes one of the tests it is sufficient. Am I thinking correctly? Thanks! 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Nov17-11, 04:13 PM | #2 |
Recognitions:
Hi tatianaiistb!
![]() Yes, it is sufficient if a matrix passes one of the tests. Each test is equivalent to each other test. Note that for test (a) the test has to pass for ALL nonzero real vectors. In other words, this is not a practical test. |
| Nov17-11, 04:34 PM | #3 |
Recognitions:
| Nov17-11, 04:57 PM | #4 |
So, if it fails one test it is sufficient to say that it is not positive definite, and viceversa? Thanks!!!!
| Nov18-11, 02:39 AM | #5 |
Recognitions:
Yep!
| New Reply |
Similar discussions for: Positive Definiteness of a Real Matrix
| Mandelstam variables positive-definiteness | Introductory Physics Homework | 0 | ||
| Symmetric Matrix and Definiteness | Calculus & Beyond Homework | 3 | ||
| Positive Definiteness | Linear & Abstract Algebra | 0 | ||
| (Semi)Positive definiteness of product of symmetric positive (semi)definite matrices | Linear & Abstract Algebra | 3 | ||
| Exchange matrix and positive definiteness | Calculus & Beyond Homework | 2 | ||
