The quantum state cannot be interpreted statistically?
by inflector
Tags: interpreted, quantum, state, statistically
bohm2
bohm2 is offline
#505
May10-12, 01:05 AM
PF Gold
bohm2's Avatar
P: 670
That Hardy paper was really confusing. A video (May 8/12) from Perimeter Institute by Robert Spekkens discussing PBR but he doesn't seem persuaded to become a psi-ontologist:
This talk will address the question of whether the PBR theorem should be interpreted as lending evidence against the psi-epistemic research program. I will review the evidence in favour of the psi-epistemic approach and describe the pre-existing reasons for thinking that if a quantum state represents knowledge about reality then it is not reality as we know it, i.e., it is not the kind of reality that is posited in the standard hidden variable framework. I will argue that the PBR theorem provides additional clues for "what has to give" in the hidden variable framework rather than providing a reason to retreat from the psi-epistemic position... The connection between the PBR theorem and other no-go results will be discussed. In particular, I will point out how the second assumption of the theorem is an instance of preparation noncontextuality, a property that is known not to be achievable in any ontological model of quantum theory, regardless of the status of separability (though not in the form posited by PBR). I will also consider the connection of PBR to the failure of local causality by considering an experimental scenario which is in a sense a time-inversion of the PBR scenario.
Why I Am Not a Psi-ontologist
http://pirsa.org/displayFlash.php?id=12050021
Demystifier
Demystifier is offline
#506
May10-12, 01:34 AM
Sci Advisor
Demystifier's Avatar
P: 4,495
Bohm2, thank you for this info. In particular, I would like to quote a part of a sentence by Spekkens above:
"... the second assumption of the theorem is an instance of preparation noncontextuality, a property that is known not to be achievable in any ontological model of quantum theory ..."
That was exactly my objection too in an early stage of this thread.
bohm2
bohm2 is offline
#507
May22-12, 04:00 PM
PF Gold
bohm2's Avatar
P: 670
An interesting PhD thesis arguing for state realism that also discusses the recent PBR theorem quite a bit. Interesting, that one of the examiners for this thesis is Robert Spekkens:
The case for quantum state realism
http://ir.lib.uwo.ca/cgi/viewcontent...ype=additional
DrChinese
DrChinese is offline
#508
May22-12, 05:21 PM
Sci Advisor
PF Gold
DrChinese's Avatar
P: 5,147
Quote Quote by bohm2 View Post
As I interpret quantum state realism: I would say that ANY 2 particles with the same eigenstates are absolutely indistinguishable. They therefore have NO HIDDEN differences. If you accept that, then you would also conclude that the collapse upon measurement absolutely changes the state and does not reveal a pre-existing characteristic. Thus you would reject the idea that it is only our knowledge which is being updated, and this is not Bayesian conditionalization.
I am not saying this is actually the case, just that is how I understand the concept. The author of the cited paper (Tait) discusses some of these ideas in detail.
yoda jedi
yoda jedi is offline
#509
Jun5-12, 01:02 AM
P: 381
Generalisations of the recent Pusey-Barrett-Rudolph theorem for statistical models of quantum phenomena
http://xxx.lanl.gov/abs/1111.6304
....For example, the ‘factorisability’ assumption used by PBR can be replaced by a far weaker ‘compatibility’ assumption for the preparations of uncorrelated quantum states.....
in agreement with leifer.
bohm2
bohm2 is offline
#510
Jun28-12, 09:16 PM
PF Gold
bohm2's Avatar
P: 670
Another paper on PBR:
The analysis of Pusey, Barrett and Rudolph aims to show there can be no objective physical reality which underlies, and is more general than, the state vector. But there appears to be a gap in their reasoning. To show their result, they use entangled states of independent systems. However, no specific experimental arrangement to detect these entangled states has been proposed. Thus their argument as it stands does not fully show there is a detectable conflict between the predictions of quantum mechanics and the existence of an underlying reality. And it is not clear that one can devise the necessary measuring device.
A problem with the Pusey, Barrett, Rudolph analysis of the reality of the quantum state.
http://lanl.arxiv.org/ftp/arxiv/pape.../1206.6491.pdf
audioloop
audioloop is offline
#511
Jul8-12, 05:21 PM
P: 461
another, leaninng to the epistemic view (can be treated statiscally)
Epistemic view of states and communication complexity of quantum channels
http://arxiv.org/pdf/1206.2961v1.pdf
...The main motivation of this paper is to show that ψ-epistemic theories, which are attracting increasing interest in quantum foundation, have a relevant role also in quantum communication.....
audioloop
#512
Oct12-12, 12:56 PM
P: 461
becoming a trend
Physical Review Letters. 109, 150404 2012
Distinct Quantum States Can Be Compatible with a Single State of Reality
http://prl.aps.org/pdf/PRL/v109/i15/e150404
...rather whether there are multiple wave functions associated with a single real state. A natural way to understand this is as an expression of the second kind of epistemic
view above—that a quantum state represents an agent’s information about an underlying reality but is not part of that reality itself...
MathOverflow
Psi-epistemic theories in 3 or more dimensions
http://mathoverflow.net/questions/95...ore-dimensions
...yes, maximally-nontrivial ψ-epistemic theories do exist for every finite dimension d...
Physics Stack Exchange
The quantum state can be interpreted statistically, again
http://physics.stackexchange.com/que...in/36390#36390
...by the way the options are:
.-only one pure quantum state corrrespondent/consistent with various ontic states.
.-only one ontic state corrrespondent/consistent with various pure quantum states.
.-only one pure quantum state corrrespondent/consistent with only one ontic state.
Ilja
Ilja is offline
#513
Oct13-12, 06:39 AM
P: 298
Quote Quote by Fredrik View Post
Their argument against the second view goes roughly like this:
Suppose that there's a theory that's at least as good as QM, in which a mathematical object λ represents all the properties of the system. Suppose that a system has been subjected to one of two different preparation procedures, that are inequivalent in the sense that they are associated with two different state vectors. Suppose that these state vectors are neither equal nor orthogonal. The preparation procedure will have left the system with some set of properties λ. If view 1 is correct, then the state vector is determined by λ, i.e. if you could know λ, you would also know the state vector. Suppose that view 2 is correct. Then either of the two inequivalent preparation procedures could have given the system the properties represented by λ. Yada-yada-yada. Contradiction!
I haven't tried to understand the yada-yada-yada part yet, because the statement I colored brown seems very wrong to me. This is what I'd like to discuss. Is it correct? Did I misunderstand what they meant? (It's possible. I didn't find their explanation very clear).
An example of inequivalent preparation procedures which lead to undistinguishable states is easy to construct in standard QM. You can prepare, using simple dices, states with probability p1 in ψ 1 and p2 in 2. This state is described by a density matrix. But the decomposition of a density matrix is not unique, so you can prepare the same density matrix in a different way, preparing other basic states 3, 4 with other proabilities.
Suppose now you find a theory where the hidden variable λ uniquely defines the density operator ρ. Then, the two different preparation procedures give the system the same observable properties as the state of the hidden variable λ.
bohm2
bohm2 is offline
#514
Oct15-12, 08:16 PM
PF Gold
bohm2's Avatar
P: 670
I know this a bit late but this interview article discussing the important PBR theorem, was a very interesting one to read for 2 important reasons:
1. Why the paper wasn't published in the original submission even after provisionally being accepted
2. Describing the connection between their 2 papers that seem to arrive at different conclusions depending on one assumption:
That preprint was submitted to Nature, but never made it in (although it did ultimately get published in Nature Physics). The story of why such an important result was shunted away from the journal to which it was first submitted (just like Peter Higgs’s paper where he first mentioned the Higgs boson!) is interesting in its own right.
Now the fun started. As this revision was ongoing, two of us submitted a preprint to the arxiv with another of our students, a paper with a somewhat tongue-in-cheek contrary title: The quantum state can be interpreted statistically. Later I will explain a bit more carefully the relation between the physics of the two papers...The theorem we prove – that quantum states cannot be understood as merely lack of knowledge of an underlying deeper reality described by some as yet undiscovered deeper theory – assumes preparation independence...That second paper is, however, simply making a mathematical/logical point-it is not a serious proposal for how the physical world operates. We are in a similar position with Bell’s theorem, which I consider the most important insight into the nature of physical reality of the last century, an honour for which there are some serious competitors! That theorem relies on a presumed ability to make independent choices of measurements at separated locations. Denial of such is the “super-determinism” loophole, and while intelligent people can and do consider its plausibility, and while it is an important insight into Bell’s theorem that this assumption is necessary, the jury is still out (‘t Hoofts efforts notwithstanding) as to whether a super-deterministic theory agreeing with all experiments to date can even be constructed, never mind be a plausible theory of nature.
Guest Post: Terry Rudolph on Nature versus Nurture
http://blogs.discovermagazine.com/co...ersus-nurture/
audioloop
#515
Oct16-12, 03:28 PM
P: 461
.-various pure quantum states corrrespondent/consistent with only one ontic state.
the latest (this month paper):
12 October 2012.
Peter G. Lewis, David Jennings, Jonathan Barrett, Terry Rudolph
bohm2
bohm2 is offline
#516
Oct23-12, 02:48 PM
PF Gold
bohm2's Avatar
P: 670
Quote Quote by audioloop View Post
12 October 2012.
Note that in the link above, Terry Rudolph does discuss that paper but he doesn't seem to take it very seriously. From the interview:
Let me briefly explain the interesting science that lies at the heart of the “key assumption” the editor is alluding to in the above. I will call this assumption preparation independence. Suppose an experiment at one lab reproduces the results of an earlier experiment at another. This would righty be called an “independent” verification of the first lab’s results. No scientist would attempt to refute this by appealing to correlations between random events at the two labs, there being no realistic mechanism for such to be established. Even in a single lab, repeated runs of an experiment must be assumed independent in order to estimate probabilities based on the results. Preparation independence is simply the assumption that we have the ability to build independent, uncorrelated experimental apparatuses to act as preparation devices of microscopic systems, and that any deeper theory of nature than quantum theory will not overthrow this principle by virtue of “hidden super-correlations” where to date scientists have always successfully assumed there are none.
The theorem we prove – that quantum states cannot be understood as merely lack of knowledge of an underlying deeper reality described by some as yet undiscovered deeper theory – assumes preparation independence. It is an important insight that this assumption is necessary for the theorem, and the point of our second paper was to show this explicitly. That second paper is, however, simply making a mathematical/logical point – it is not a serious proposal for how the physical world operates.
Demystifier
#517
Oct24-12, 03:41 AM
Sci Advisor
P: 4,495
It's good to know that.
Demystifier
#518
Dec14-12, 10:36 AM
Sci Advisor
P: 4,495
A recent explanation of the PBR theorem at a level suitable for a general physicist audience is presented here:
http://www.physicsforums.com/blog.php?b=4330
DrChinese
#519
Dec14-12, 12:45 PM
Sci Advisor
PF Gold
DrChinese's Avatar
P: 5,147
Quote Quote by Demystifier View Post
Nicely done presentation!
rkastner
rkastner is offline
#520
Dec14-12, 05:36 PM
P: 158
I present a *non-statistical,* realist QM interpretation in my new book:
http://www.cambridge.org/us/knowledg...US&code=L2TIQM
RK
bohm2
bohm2 is offline
#521
Dec14-12, 09:56 PM
PF Gold
bohm2's Avatar
P: 670
Much appreciated!
audioloop
#522
Dec15-12, 08:41 AM
P: 461
..."Does there exist a maximally-nontrivial ψ-epistemic theory in dimensions d≥3?"...
..."The answer to my (and Lewis et al.'s) question is that yes, maximally-nontrivial ψ-epistemic theories do exist for every finite dimension $d$"...
Register to reply
Related Discussions
The nature of the universe as interpreted quantum information General Discussion 6
statistically independent confusion Set Theory, Logic, Probability, Statistics 4
Can DNA be interpreted differently? Biology 11
