When heating a tube containing two solid substances, the temperature will remain constant at the melting point of the substance with the highest melting point until the lower melting point substance has completely melted. This occurs because the melting process absorbs heat, preventing a temperature increase during the phase change. Once the lower melting point substance is fully melted, the temperature will then rise to the melting point of the higher melting point substance. It's important to note that a significant quantity of the substances is needed to observe this constant temperature effect. Additionally, the interaction between the two substances is crucial; if the second substance does not dissolve in the first, it can further influence the melting behavior and temperature stability.
