Integrating 1/(Z^2 + A^2) - something wrong?
  • Thread starter Thread starter Froskoy
    Integrating
The discussion centers on the integration of the function \(\int \frac{1}{2t^2+4} \mathrm{d}t\) and the discrepancies observed between two methods of solving it. The first method yields \(\frac{1}{2} \arctan{(\frac{\sqrt{2}t}{2})} + c\), while the second method introduces an extra factor of \(\frac{1}{\sqrt{2}}\). The confusion arises from the omission of the \(\sqrt{2}\) factor in the differential \(dt\) in the first integral, which leads to the inconsistency. The correct application of integration techniques is crucial for accurate results.
  • Understanding of integral calculus, specifically integration techniques.
  • Familiarity with the arctangent function and its properties.
  • Knowledge of substitution methods in integration.
  • Ability to manipulate algebraic expressions involving square roots.
  • Review integration techniques involving trigonometric functions, particularly arctangent.
  • Study the method of substitution in integral calculus.
  • Practice solving integrals that involve square roots and rational functions.
  • Explore common pitfalls in integration to avoid errors similar to the one discussed.
Students of calculus, mathematics educators, and anyone looking to deepen their understanding of integration techniques and common errors in solving integrals.
Froskoy
[tex]\int \frac{1}{2t^2+4} \mathrm{d}t[\tex]<h2>Homework Equations</h2><br /> [tex]\int \frac{1}{Z^2+A^2} \mathrm{d}Z = \frac{1}{A} \arctan{(\frac{Z}{A})} + c[/tex]<h2>The Attempt at a Solution</h2><br /> Looks quite easy, but this is what's annoying me: the two methods below should be identical, but something's gone wrong and I can't work out what. For some reason, the second method gives an extra factor of 1/sqrt(2) at the front. Why aren't they both the same?<br /> <br /> [tex]\int \frac{1}{2t^2+4} \mathrm{d}t = \int \frac{1}{(\sqrt{2t})^2+2^2} \mathrm{d}t = \frac{1}{2} \arctan {(\frac{\sqrt{2}t}{2})} + c[/tex]<br /> <br /> [tex]\int \frac{1}{2t^2+4} \mathrm{d}t = \frac{1}{2} \int \frac{1}{t^2+2} = \frac{1}{2 \sqrt{2}} \arctan{(\frac{\sqrt{2} t}{2})}+c[/tex]<br /> <br /> With very many thanks,<br /> <br /> Froskoy.[/tex]
Are you sure that c represents the same value in each?
Froskoy said:
[tex]\int \frac{1}{2t^2+4} \mathrm{d}t[\tex]<br /> <br /> <br /> <h2>Homework Equations</h2><br /> [tex]\int \frac{1}{Z^2+A^2} \mathrm{d}Z = \frac{1}{A} \arctan{(\frac{Z}{A})} + c[/tex]<br /> <br /> <br /> <h2>The Attempt at a Solution</h2><br /> Looks quite easy, but this is what's annoying me: the two methods below should be identical, but something's gone wrong and I can't work out what. For some reason, the second method gives an extra factor of 1/sqrt(2) at the front. Why aren't they both the same?<br /> <br /> [tex]\int \frac{1}{2t^2+4} \mathrm{d}t = \int \frac{1}{(\sqrt{2t})^2+2^2} \mathrm{d}t = \frac{1}{2} \arctan {(\frac{\sqrt{2}t}{2})} + c[/tex]<br /> <br /> [tex]\int \frac{1}{2t^2+4} \mathrm{d}t = \frac{1}{2} \int \frac{1}{t^2+2} = \frac{1}{2 \sqrt{2}} \arctan{(\frac{\sqrt{2} t}{2})}+c[/tex]<br /> <br /> With very many thanks,<br /> <br /> Froskoy.[/tex]
[tex] <br /> You forgot to use [itex]\sqrt{2} dt[/itex] in the first integral.<br /> <br /> RGV[/tex]
  • · Replies 105 ·
13K
  • · Replies 22 ·
