| New Reply |
Checking a question involving impact/impulse forces |
Share Thread | Thread Tools |
| Jan20-12, 09:44 AM | #1 |
A ceramic pot of mass 0.5 kg will break if it strikes the floor with an impact force equal to, or greater than, 20 N. The collision lasts for 0.05 s. Find the minimum vertical height from which, if dropped from rest, the pot will break upon impact with the floor (you may ignore air resistance). 2. Relevant equations Impulse=FΔt=Pfinal-Pinital Fd=ΔKinetic energy PE=mgh KE=1/2mv2 3. The attempt at a solution At a height h, the object has KE=0 and PE=mgh=0.5gh At impact, the object has KE=1/2mv2=0.25v2 and PE=0 FΔt=Pf-Pi However Pi=0 as the velocity is 0. equation 1: 20*0.05=Pf=mv=0.5v to find v: 1/2mv2=mgh rearrange to give v=√2gh back into equation 1: 1=0.52*2gh h=1/0.52*2*9.81 h=0.2m Is this correct? That doesn't seem big enough in order for the pot to break (thinking in real world terms) |
| Jan20-12, 10:20 AM | #2 |
You need to use the fact that force = change in momentum per second.
They give you the force so you need to get momentum information Do you know how? |
| Jan20-12, 10:25 AM | #3 |
That's what I attempted to do with the Pf-Pi with P being momentum (mv) ... is that not the right equation?
| Jan20-12, 10:34 AM | #4 |
You are correct and if you look at your equation 1 you see that v = 2 m/s ?
So 2 = √2gh. |
| Jan20-12, 11:03 AM | #5 |
Perfect - thanks :)
| New Reply |
| Thread Tools | |
Similar Threads for: Checking a question involving impact/impulse forces
| Two Impulse & Impact Problems! Need Help! | Introductory Physics Homework | 1 | ||
| Statics Question involving forces and moments | Engineering, Comp Sci, & Technology Homework | 2 | ||
| IB 11 Question: Circular Acceleration Problem Involving Forces | Introductory Physics Homework | 5 | ||
| IB 11 Question: ANOTHER Circular Acceleration Problem Involving Forces | Introductory Physics Homework | 1 | ||
| momentum, impulse, impact | Introductory Physics Homework | 1 | ||
