Why Does This Infinite Series Converge at Certain Values of x?
In summary, the conversation is about a student struggling with a math problem involving a series and trying to find the set of x for which the series converges and the sum of the series at those values. The student is confused about the wording of the question and the process of finding the sum when x=-10 and x=-4. They also discuss potential solutions and ask for clarification from others.
skyturnred
118
Ugh really getting frustrated at not being able to keep up with math..
Find the set of x for which the series converges AND find the sum of the series at these values.
s=[itex]\sum^{k=infinity}_{k=0}[/itex] [itex]\frac{(x+7)^{k}}{3^{k}}[/itex]
OK, by using the ratio test I find the set to be x=(-10,-4). I entered this in, and this is correct. But I am very confused about the second part of the question.. starting with the wording.
Is it asking me to find the sum at x=-10, THEN the sum at x=-4, and then add them? I ask this because there is only ONE field in which to input the answer.
But regardless of whether it is asking that, I am finding it difficult to find the sum when x=-10.
I get the sum of (-1)[itex]^{k}[/itex] from k=0 to k=n as n approaches infinity. So I get the sum of
s=1-1+1-1+1+...(-1)[itex]^{n-1}[/itex]+(-1)[itex]^{n}[/itex]
My initial thought was that s=0, because all the terms would cancel out. Then I realized, it could also equal 1 because as n approaches infinity, the terms would always change between 1 and -1. So I couldn't decide between the two.
But THEN I entered it into wolfram alpha, and it says that the series is equal to 1/2! How does this even make sense? Can someone explain please?
But I am very confused AGAIN for the following: When I try x=-4, I get the sum of 1+1+1+1+1+... n times (so it should be infinity). And if the original question is asking to add these series together, then it shouldn't matter whether the sum when x=-10 is 0, 1, or even 1/2, because any of those values plus infinity is equal to infinity. But when I input this into the answer area, I get it wrong. What am I doing wrong?
Thanks.
Thanks.
You have a sum of the form [tex]S(x) = \sum_{k=1}^\infty y^k, \mbox{ where } y = \frac{x+7}{3}. [/tex]
Surely you have seen such sums hundreds of times already.
To me the question seems perfectly clear: evaluate S(x) for any value of x in the convergence region. It does not ask you to sum S(x) for different values of x, because that would make no sense at all: summing S(x) for a continuous x is not a defined operation (although integrating S(x) would be). Certainly you should never attempt to add the values of S at the endpoints of the convergence region because these values may not exist: convergence regions of infinite series are open intervals, and the series might (usually does) diverge at the endpoints of these regions.
PS: in tex the command for ∞ is "\infty", not "\infinity" or "infinity".
RGV
I have not seen hundreds of such sums or hundreds of ANY infinite sums for that matter. I am attending a first year calculus course in which we only just started sums last friday. I would not post a question to physicsforums unless I cannot figure it out.
With all due respect, you must be wrong here. There is a single answer field in which to input a response. Since the answer changes as x changes from -10 and -4, this is clearly not what is expected. This is backed by a few of my fellow engineering majors who have tried what you mentioned above, and had the wrong answer.
Im sorry for this simple mistake that obviously did not change the question in any way nor could possibly have annoyed anyone with normal tolerance/ patience levels.
Thanks anyways
It's a geometric series, which, in the US at least, is covered in high school math and probably in junior high. You've likely seen it before but have since forgotten about it.
The question is asking you for the sum of the series at values of x for which it converges. There's an infinite number of possible values, so obviously you're supposed to come up with an expression S(x) that depends on x. Your interpretation can't possibly be right because S(-10) and S(-4) don't exist.
I get the sum of (-1)k from k=0 to k=n as n approaches infinity. So I get the sum of
s=1-1+1-1+1+...(-1)n−1+(-1)n
When you say an infinite series converges, it means the sequence of partial sums sn converges. In this case, you find sn flips back and forth between 1 and 0 (not -1), so the series doesn't converge.
Why would you suppose I was imptatient or annoyed?YOU used Tex, but got the infinity sign wrong, so I thought you might like information on how to do it right. As for never having seen such a series before: if you haven't, I am truly surprised, especially in a "Calculus and beyond" forum.
RGV
RGV
I apologize for being rude. Although it's no excuse, I have just been getting increasingly frustrated at simply not understanding what many others in my faculty seem to be able to understand in their sleep.
Also, I went to a terrible high school. Almost none of my graduating class went on to post-secondary education. I'm almost positive we didn't do series. I asked my friend who also went to my high school and he says the same thing.
Thanks for letting me know this, I wasn't quite understanding exactly what divergence meant. I thought a sum HAD to go off to infinity for it to be "divergent," but I guess it is considered "divergent" if it doesn't converge as well.
Unfortunately, it wouldn't be terribly surprising if that is indeed the case. Fortunately, the geometric series isn't terribly difficult to master even if you are seeing it for the first time.
Yeah, that's a common mistake. It seems like diverge should mean it goes off to infinity, but in the context of series, it simply means doesn't converge.
Re your statement ".. I have just been getting increasingly frustrated ..". You probably won't want to hear this, but: the way to gain proficiency is to do it again and again and again ... It's the old cliche that 'practice makes perfect'. Also: don't feel bad about making mistakes; just try to learn from them (although, of course, it would be nicer to not make mistakes on marked assignments).
Also: about having a single answer field: are you doing an on-line course, or are the assignments given on-line? Unfortunately, in this Forum it happens over and over again that people submit correct solutions to on-line questions and are marked wrong. There are some genuine unsolved technical issues with designing robust on-line assigment marking schemes.
RGV
1. What is an infinite series?
An infinite series is a sum of an infinite number of terms. The terms can either increase or decrease in value, and the series can have either a finite or infinite sum.
2. How do I know if an infinite series converges or diverges?
There are various tests that can be used to determine the convergence or divergence of an infinite series, such as the ratio test, the comparison test, and the integral test. It is important to note that these tests do not always give a definite answer and may require further analysis.
3. Can I use a calculator to solve an infinite series?
While a calculator can be helpful in calculating the sum of a finite series, it is not possible to use a calculator to determine the convergence or divergence of an infinite series. This requires a deeper understanding of the series and its properties.
4. How do I know which test to use for a specific infinite series?
Choosing the appropriate test for a specific infinite series can be a bit tricky. It is important to first understand the properties of the series, such as whether it is a geometric series, a telescoping series, or a p-series. From there, you can then choose a test that is most suitable for that type of series.
5. Can you give me an example of an infinite series and how to solve it?
Sure! An example of an infinite series is the geometric series: 1 + 1/2 + 1/4 + 1/8 + ... As long as the common ratio (in this case, 1/2) is less than 1, this series will converge. To find the sum, you can use the formula: S = a/(1-r), where S is the sum, a is the first term, and r is the common ratio. So in this case, the sum would be 1/(1-1/2) = 2.
