What does torque of 5 kg.cm meant by , for a dc geared motor?
  • Thread starter Thread starter dexterdev
    Dc Motor Torque
The torque rating of 5 kg.cm for a DC geared motor indicates the maximum torque the motor can exert at a distance of one centimeter from its axis. This means the motor can theoretically handle a load of up to 5 kg, but actual load capacity depends on factors like RPM and the motor's efficiency. Torque is inversely related to RPM; as RPM increases, torque decreases. Proper conditions, such as ensuring the motor is not overloaded and maintaining optimal operating speeds, are crucial for performance. Understanding these parameters is essential for effective motor application.
dexterdev
what does torque of 5 kg.cm meant by for a dc geared motor? can I give a load upto 5 kg for that motor? If so what are the conditions? Is torque related to RPM?
thanks for reply
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
