New Reply
Magnitude of object with constant speed
Share Thread Thread Tools
Feb24-12, 09:32 AM   #1
in the physics laboratory experiment, a 6 kg box is pushed across a flat table by horizontal force F. if the box is moving at a constant speed of 0.35 m/s and the coefficient of kinetic friction is 0.12. what is the magnitude of F.
2. Relevant equations
F=μ*Fn
where
F = friction
μ = coefficient of friction
Fn = normal force
Fn = mass of object * acceleration
3. The attempt at a solution
i solve for Fn first,
Fn = 6 kg * 0 m/s2
and got an answer of zero for normal force.... i let the acceleration to be zero because it says that it has constant speed..... Is it normal to have a zero normal force?
and then when i solve for the magnitude of friction....
F = 0.12*0
which is zero also... O.o.....
i'm not sure if i got a wrong equation, but i think its correct...... or if i got some wrong interpretation of the given values that results to zero friction.......
My question is, is it a normal thing for an object with constant speed to have a zero friction?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb24-12, 09:49 AM   #2
Mentor
Quote by Kamirusen View Post
Fn = normal force
That's not how you find the normal force. Consider the vertical forces acting on the box.
Feb24-12, 10:32 AM   #3
thanks for reply...
so ill gonna consider the acceleration due to gravity of an object with no horizontal acceleration?
Feb24-12, 10:53 AM   #4
First and fore most, never solve Newton Laws Problems without FBD. Draw the figure and correctly denote the directions in which the forces acts. Use F(net)=Ma along x-y axes. See what happens.
Feb24-12, 03:01 PM   #5
Mentor
Sure. You'll need it to find the object's weight.
Just because you might use the acceleration due to gravity does not mean the object must be accelerating. Think of the acceleration due to gravity as a measure of the strength of the earth's gravitational field.
Feb24-12, 03:25 PM   #6
In this case
##F_N=mg## m = mass, g=gravity, gravity pulls down with 9.81m/s^2 so find normal force
##F_N=6kg*9.81\frac{m}{s^2}=58.86N##
If you're trying to move the body in constant velocity then
##F_{net}=0## because:
##F_{net}=ma##
##F-F_f=ma##
##F-F_f=m * 0##
##F-F_f=0## so friction is equal to pushing force.
so simply find friction ##F_f=\mu F_N## and that's the pushing force
Feb25-12, 09:08 PM   #7
thanks !!! its clearer now... :)
New Reply
Tags
acceleration, constant speed, frictional force, kinetic friction, normal force
Thread Tools
Similar Threads for: Magnitude of object with constant speed
Thread Forum Replies
Work Done By A Force of Constant Magnitude in Moving an Object in a Circle Introductory Physics Homework 2
Force On Object With Constant Speed Advanced Physics Homework 2
Constant velocity object catching up to an accelerating object Introductory Physics Homework 3
Why does an object have constant speed with Centripetal Force Introductory Physics Homework 5
Object with constant speed does not lose kinetic energy when faced with resistance General Physics 3
