How Do You Find the Equation of a Plane That Contains a Line of Intersection?
  • Thread starter skyturnred
  • Tags
    Plane
In summary: If t=1, you have (x,y,z) = (-4, 9, 1) .Both points are on the line of intersection.You're done. In summary, the plane that passes through the given point (-3, 2, 1) and contains the line of intersection of the planes x + y − z = 3 and 4x − y + 5z = 5 has the equation 6x-19y+39z=-17. To find this, you can take the cross product of the normal vectors of the two planes and use an arbitrary point on the line of intersection to find the direction vector of the plane. Then, using the equation of a plane, you
skyturnred
118
The plane that passes through the point
(−3, 2, 1)
So I plugged the planes into a matrix and found the line of intersection with one parameter. I took the coefficients as the direction vector of the line. Plugging that into an equation of the plane, I get the following:
(5/6)X-(19/5)Y+(56/5)Z
but it says I'm wrong. I only have 1 attempt left at the right solution.. Please help! Thanks in advance!
(−3, 2, 1)
The plane you're looking for is the plane containing the given point and the line of intersection.
What did you get for the parametrization of the line of intersection?
I did the work a couple days ago and lost it.. but now that I re-do it, I don't remember what it was. But I DO remember not have any clue what I was doing.
Anyways, the equation of the line of intersection is
x=(-4/5)t
y=(9/5)t
z=t
so I have to include this line.. in other words, the norm of the plane will be orthogonal to it right? But finding a direction vector that is orthogonal to that is a plane on it's own.. and I can't quite think of what to do.
All I know is that it probably has to do with some of the following:
I know that the dot product between two orthogonal vectors is 0
I know that the cross product between two vectors produces a vector that is orthogonal to both
I realize that my answer that I showed above was actually an expression rather than an equation... but regardless, I'm pretty sure it's wrong anyways.
That's about all I know though..
x=(-4/5)t
y=(9/5)t
z=t
That parametrization goes through the point (0,0,0).
Neither plane contains such a point.
However, both planes contain the point, [itex]\displaystyle \left(\frac{8}{5}\,,\ \frac{7}{5}\,,\ 0\right)\,,[/itex] so the line of intersection passes through this point.
An interesting way to approach this problem is to realize that any linear combination of the equations for the two planes, results in another plane which intersects the two given planes along that same line. Find the linear combination which also contains the point, (-3, 2, 1) .
EDIT 2: I think I may have found the right answer. I don't know what I was finding before by solving the matrix of the coefficients of the two planes.. but I did it the following way:
The line of intersect will be orthogonal to both of the normal vectors of the planes. So I did the cross product of both of their normal vectors and get (4,-9,-5)
I found an arbitrary point on the line intersection by choosing z=0 and solving for x and y and I get the point:
(8/5, 7/5, 0)
The difference between this point and the given point in the question will be another direction vector in the unknown plane. So now that I know two directional vectors that are in the plane, I did the cross product to find the normal vector of the plane in question. I get the following:
(6, -19, 39)=n
And then using this and the point given in the question (and the equation of a plane) I get the following as the equation of the plane:
6(x+3)-19(y-2)+39(z-1)=0
Is this correct? I only have one attempt left at the right answer.
Also, by solving the matrix made by the coefficients of the planes, what am I finding? I must be finding something useful..
1 0 (4/5) (8/5)
0 1 (-9/5) (7/5)
I get:
z=t
y=(9/5)t
x=(-4/5)t
(8/5, 7/5, 0)
(6, -19, 39)=n
The method is correct.
It seems to check out.
It simplifies to 6x-19y+39z=-17.
1 0 (4/5) (8/5)
0 1 (-9/5) (7/5)
I get:
z=t
y=(9/5)t
x=(-4/5)t
If t=-5, you have (x,y,z) = (4, -9, -5) .
Related to How Do You Find the Equation of a Plane That Contains a Line of Intersection?
What is the definition of a plane in mathematics?
A plane is a two-dimensional flat surface that extends infinitely in all directions. It is defined by three non-collinear points or by a point and a normal vector.
How do you find the equation of a plane given three points?
To find the equation of a plane, you can use the formula Ax + By + Cz + D = 0, where A, B, and C are the coefficients of the x, y, and z variables and D is a constant. You can plug in the coordinates of the three points into this equation and then solve for the coefficients.
What is the significance of the normal vector in the equation of a plane?
The normal vector represents the direction perpendicular to the plane. It is important because it helps determine the orientation of the plane and is used to calculate the distance from a point to the plane.
Can a plane equation have fractions or decimals as coefficients?
Yes, a plane equation can have fractions or decimals as coefficients. The coefficients represent the slope or direction of the plane, so they can be any real number.
How do you find the equation of a plane in vector form?
To find the equation of a plane in vector form, you can use the formula r ⋅ n = p ⋅ n, where r is a position vector, n is the normal vector, and p is a point on the plane. This equation represents all the points on the plane and can be written as r = p + s ⋅ n, where s is a scalar.
