New Reply
Rope climbing robot
Share Thread Thread Tools
Apr11-12, 12:59 AM   #1
Rope climbing robot
Hey guys I have a freaking project that requires me to build a rope climbing robot that cannot be powered by chemical based. Basically no batteries as such are required.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Apr11-12, 05:46 AM   #2
Some background info about the scale and expected complexity of the project will be good to have. Right now I have no clue if you mean just a spring-loaded toy that'll pull on 10 cm of sewing thread, or something like the space elevator climber challenge.
http://www.spaceward.org/elevator2010-pb
Apr11-12, 06:01 AM   #3
We're basically required to build a robot that is non-chemically powered to climb a rope of 8mm thick to a height of approximately 1.5m
Apr11-12, 07:18 AM   #4
Rope climbing robot
Quote by carzygoul View Post
we're basically required to build a robot that is non-chemically powered to climb a rope of 8mm thick to a height of approximately 1.5m
Simplest thing that comes to mind: Two connected rollers with rubber bands inside, which you wind up.
PHP Code:
o|o
Apr11-12, 08:47 AM   #5
hmm what if i use a pullback or wind-up motor... u think can climb better?
Apr11-12, 10:06 AM   #6
If you have one, you can try. But keep in mind that the weight counts. Rubber bands are light.
New Reply
Thread Tools
Similar Threads for: Rope climbing robot
Thread Forum Replies
Need help with structure of stair climbing robot Mechanical Engineering 3
Pole Climbing Robot, Please Help!? Engineering, Comp Sci, & Technology Homework 4
to design linkeges of wall climbing robot Mechanical Engineering 1
Calculating the minimum vacuum force for a climbing robot Introductory Physics Homework 1
Pole Climbing Robot, Please Help!? Mechanical Engineering 3
