So, what does this mean for the physical interpretation of a point dipole?
  • Thread starter Thread starter ShayanJ
    Dipole Point
A point dipole is defined as a dipole whose size is negligible compared to the distances involved in the problem, meaning all relevant distances are much larger than the separation between the charges. This interpretation allows for the dipole moment to remain finite while the charge approaches infinity as the distance between the charges tends to zero. However, it does not imply that the distance is infinitely small; rather, the charge remains finite in practical applications. Examples include scenarios where the dipole's influence is considered at large distances, such as in electromagnetic fields. Understanding this concept is crucial for accurately modeling physical systems involving dipoles.
ShayanJ
Insights Author
Mathematically,its easy to say that when the distance between the points tends to zero,for the dipole moment to stay finite,the charge should tend to infinity.
My question is,how should I interpret it?
What is a point dipole physically?
Could you give examples?
thanks
You can interpret it as a dipole which is so small that its size does not matter. This implies that all relevant distances in your problem are much larger than the size of the dipole, and higher moments (quadrupole, ...) do not matter.
Shyan said:
...for the dipole moment to stay finite,the charge should tend to infinity.
When we say a point dipole we mean that the distance at which are calculating electric field is much greater than the distance between the charges .
eg 1cm is very small before 10km
But it does not mean that the distance itself is infinitely small. Hence charge would also be finite.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
