Stretched wire potentiometer, Conceptual help
The discussion revolves around understanding the operation of a stretched wire potentiometer, particularly the concept of voltage potential along the wire. The user is confused about why current does not flow from a higher potential point (A at 10V) to a lower potential point (a at 5V) when connected, despite the book stating that points a and A have the same potential due to negligible resistance in the wire. Clarifications highlight that the potentiometer wire has significant resistance, resulting in a regular voltage drop along its length, allowing for voltage measurement at various points. The key takeaway is that the potentiometer measures voltage differences, and no current flows when the voltages are balanced at the contact point. Understanding this principle is essential for effectively using a potentiometer in voltage measurement applications.
amk_dbz
I am having problem understanding the working of Stretched wire potentiometer.
Now the book says that the potential of a and A are same because the wire Aa has negligible resistance. That is were the problem comes for me. Suppose the batter connected to AB be of 10V (assume negative terminal to be of 0V) and the one connected to ab be 5V(assume negative terminal to be of 0V). Now the pt a is at 5V and A is at 10V, therefore current should flow from A to a, but this doesn't happen, Why?
Any help will be appreciated. Thank you.
(check the image of circuit diagram of potentiometer. Sorry for bad quality, I am not a good painter.) :smile:
Are you sure you have copied the diagram completely and correctly?
A potentiometer measures voltage.
You cannot measure resistance with a potentiometer alone.
You can compare resistance with a known standard.
Or you can independently measure the current through the unknown resistance and use the potentiometer to measure the voltage across the unknown resistor and then calculate the resistance from Ohm's law.
Do you understand the basic operation of a potentiometer?
I am a bit confused but what you said is correct. The potentiometer measures the potential difference and not the resistance (Sry for the mistake).
I am a bit confused
We can only help with more information.
I am a bit confused due to the problem I am facing as told in the first post. Other things are clear. So, could you help me with the problem? I haven't been able to find a satisfactory answer for it for a month or two, so any help will be much appreciated.
Thank you.:smile:
So is this your issue?
The wire that the potentiometer is made of is special wire with significant resistance per millimetre. The wire is not ordinary copper wire that is designed to have as little resistance per millimetre as possible.
When we connect two points (eg Aa) by ordinary copper wire we can say they are at the same voltage because the resistance of the connecting wire is negligible.
But when we connect say 10 volts across the potentiometer wire there is a regular voltage drop of 10 volts over 1000 millimetres or 1/100 volts per millimetre, or 1 volt every 100 millimetres. Since the voltage drop is regular (even) we can measure it by measuring distance along the wire.
So at a point at say 400mm from the zero end the voltage is 400 * 1/100 = 4 volts
If the voltage along the whole potentiometer wire is greater than the voltage you wish to measure then somewhere along the wire it must equal the that voltage.
So you can compare voltages by sliding a contact along the wire until the voltage at b and the slider (in your diagram) are equal.
Since they are equal no current flows through the galvanometer.
How are we doing? are we making progress?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
12K
