Design a Yaw Controller for a Toy Quad-Copter
  • Thread starter Thread starter stosw
    Controller
A user is developing a yaw controller for a programmable toy quad-copter to navigate to specified coordinates. They are currently calculating the necessary turning angle using the starting and destination points, which works well for stationary targets. However, the quad-copter struggles to maintain its position while rotating, complicating the yaw control. The discussion emphasizes the interdependence of roll, pitch, and yaw, noting that they should not be considered in isolation. A referenced paper provides insights on tuning the control loops for better performance.
stosw
I've been currently playing around with a toy quad-copter that you can write your own programs for and was attempting to make it go to a set of coordinates that are specified. I was wondering if someone could help me design a controller for the yaw component.
I am currently calculating the angle needed to turn by take the two points, starting and destination, and using a triangle to find the angle. This works great for a stationary object and turns to the desired angle. The problem comes from the toy not staying directly in place while rotating.
Any input would be greatly appreciated.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
