Projectile motion problem where the projectile is a rocket
The problem involves a rocket launched at an angle of 53° with an initial speed of 75 m/s and an acceleration of 25 m/s². After 30 seconds, the rocket's engine fails, and it transitions to projectile motion. The questions posed include determining the maximum altitude, total time of flight, and horizontal range of the rocket.
  • Mixed
  • Participants discuss resolving the initial velocity into x and y components and the use of various kinematic equations to find maximum altitude and other parameters. There are attempts to differentiate equations to find extrema and questions about the appropriateness of using gravitational acceleration in calculations.
Some participants have shared calculations and results, while others are seeking clarification on specific terms and methods. There is an ongoing exploration of different approaches to the problem, with no clear consensus reached yet.
Participants are navigating through the implications of transitioning from powered flight to projectile motion, and there are discussions about the definitions and values of acceleration during different phases of the rocket's flight.
isTheReau
A rocket is launched at an angle of 53° above the horizontal with an initial speed of 75 m/s. It moves in powered flight along its initial line of motion with an acceleration of 25 m/s^2. At 30 s(seconds) from launch, its engine fails and the rocket continues to move as a projectile.
(a) What is the rocket's max altitude? (ymax)
(b) What is the rocket's total time of flight? (tτ)
(c) What is the rocket's horizontal range? (R/x)
My given information looks like this: θ= 53°, v1= 75 m/s, a=25 m/s, t= 30s, Δy=0
x=vcosθt
y=vsinθt+.5at^2
ymax= -(vsinθ)^2/2a
I tried resolving the velocity into x and y components but I'm not even sure if that's useful information. I also attempted to use the above equations but to no avail... I just need to get this started so that I can finish it. The problem is I'm not sure where to start.
x=vcosθt
y=vsinθt+.5at^2
ymax= -(vsinθ)^2/2a
Yes, these formulas are useful to determine the certain components. To find the altitude, you need to use the second formula: y=vsinθt+.5at^2
Substitute the given values and try to find the max. You can perform the differentiation if you know calculus.
dy/dt = vsinθ + at
Then, let dy/dt = 0 and solve for t. This gives you the extrema if a = g = -9.81.
I found y using the second equation and got 13,046 m... Would that be ymax? I wasn't sure.
Actually not. You actually solve for t for the dy/dt equation where dy/dt = 0, so we have...
0 = vsinθ + at
t = -vsinθ/a
Now, find the value of t via substitutions. Know that:
θ = 53°
v = 75
a = g = -9.81
Finally, substitute the t value for y = vsinθt + ½at²
okay... and when I solve that, would that be the ymax?
and why are you using -9.81 for the acceleration?
Given θ= 53°, v0= 75 m/s, a=25 m/s2, t= 30s
First part of flight
v1-v0=at
v1=825m/s
ddia=0.5x825x30=12375m
2nd part of flight.
Given θ= 53°, v0= 825 m/s, a=-9.8 m/s2, v1=0
Maximum height is maximum height of 2nd. part plus y component of ddia.
what is d sub dia?
like... diagonal distance?
Okay i think I get it now... thank you!
isTheReau said:
what is d sub dia?
Yes
Sorry, i should have defined it.
Anyway you got it.
  • · Replies 53 ·
  • · Replies 18 ·
