Two Objects Dropping: Do Weights Matter?
  • Context: High School
  • Thread starter Thread starter B-Con
    Falling
The discussion revolves around the behavior of two objects with different weights when dropped from a height, specifically examining the effects of gravity, mass, and air resistance on their fall. Participants explore theoretical implications, mathematical formulations, and conceptual understandings related to gravitational attraction and inertia.
  • Some participants propose that two objects dropped from a height will hit the ground at the same time regardless of their weights due to equal air resistance.
  • Others argue that the heavier object, having more mass, might technically fall slightly faster due to gravitational attraction, though this difference is considered negligible in practical terms.
  • Mathematical relationships are presented, such as potential energy equating to kinetic energy, leading to the conclusion that mass cancels out in the equations.
  • Some participants express confusion about how mass does not affect gravitational attraction, suggesting that the Earth is also attracted to the falling object, which could imply a difference in the distance traveled before impact.
  • One participant discusses inertia, suggesting that while a more massive object feels a greater force, it also resists changes in velocity due to its mass, leading to a balance that results in equal acceleration for both objects.
  • Several participants challenge the initial claim about equal fall times, emphasizing that air resistance plays a significant role, especially when comparing objects of different shapes and densities.
Participants generally disagree on the implications of mass and air resistance in the context of falling objects. While some assert that weight does not affect fall time under ideal conditions, others highlight the importance of air resistance and the specific conditions under which the discussion applies, such as the assumption of a vacuum.
Participants note that the discussion assumes ideal conditions, such as a vacuum, where air resistance is not a factor. The mathematical derivations presented do not account for real-world complexities that could affect the outcomes.
B-Con
If I were to drop two objects with equal air resistance from a building, regardless of their differing weights, they would hit the ground at the same time.
However, since they both have different weights, they also will have different masses, and since gravitational attraction is based on mass, wouldn't the heavier one, because it possesses more mass, technically fall *slightly* faster? the difference in speed would be invisible to a human watching them fall, but wouldn't it technically fall faster?
Well, when you deal with energy, say you want to find the speed right before it hits the ground...
potential energy = kinetic energy
mgh = .5mv^2
Notce the mass cancels out
gh = .5v^2
v = sqrt(2gh)
Oh, I see. Now for attractive force the equation is
Force = GMm/D^2
and we know F = ma
so equate GMm/D^2 = ma
Notice the little m for mass cancels out. Just like the energy one. This explains it mathematically, but why disregarding mathematics...hmmmm
Ok, the math makes sense, but logically I don't get there... how could the falling objects mass not have an effect on the gravitational attraction?
ok, technially, both objects involved in the gravitational attraction (here it's the Earth and the falling ball) exert forces on each other, thus the Earth is also simotaniously being attracted to the falling object, the Earth's attraction to the ball will be minute, but nonetheless existant, thus the Earth's attraction will be greater towards the bigger ball and less toward the smaller ball, meaning that the heavier ball will technically fall at the same rate as the smaller one, but the Earth will be attracted to it more, meaning that it has "less" distance to travel before striking the Earth since the Earth moves some microscopic distance toward it... right?
Well, all objects that have mass have inertia, right? Inertia resists change in velocity. Now since gravity ofcourse is an acceleration, it is ?v/?t or dv/dt.
So it looks like a more massive object does infact feel a greater force, but resists change in dv/dt because it is more massive. A lesser object feels less force but is less hindered by inertia. It's like the inertial and gravitational forces cancel each other out.
This is the best explanation I can think of
Essentially correct, but for normal sized objects (balls and such--as opposed to moons) the acceleration of the Earth is ludicrously insignificant. Check this out: https://www.physicsforums.com/showpost.php?p=343562&postcount=16
relativitydude, I coincedentally read the same explanation in Stephen Hawking's "A brief history of time" book just an hour before, that makes sense...
thx Doc, that also helps, and that is truly an "amusing thought experiement"... ;)
This is not true; not even close. A pingpong ball and a lead sphere of the same size have, at the same falling speed, the same air resistance. Yet the lead weight will fall to the ground much faster than the pingpong ball.
Good catch, krab. Only if gravity is the only force on the balls, will their accelerations be equal. This gedanken experiment requires a vacuum.
true, I failed to specify in a vaccume, I kinda thought it was assumed... my bad ;)
  • · Replies 23 ·
  • · Replies 51 ·
  • · Replies 41 ·
9K
  • · Replies 33 ·
