Optical DIY Telescope: Optics Guide for Using Magnifying Glasses
To create a homemade telescope using magnifying glasses, the distance between the objective lens and the eyepiece should be less than the sum of their focal lengths (distance < 3F) to achieve magnification. The magnification is determined by the ratio of the focal lengths of the two lenses, with the longer focal length serving as the objective and the shorter as the eyepiece. For practical purposes, a distant light source can be used to find the focal lengths instead of waiting for sunlight. To correct the inverted image produced by the two lenses, a mirror set at a 45-degree angle can be used, although this will only laterally invert the image. For a fully erect image, a pair of prisms, as used in binoculars, is recommended.
lindloda
Okay so I want to make a telescope at home...
Im not a noob. Even if I am please just help me.
I've got a couple of magnifying glasses ..pretty big ..
I don't know the exact focal length...
But one of them is twice the size of other...
As soon as the sun comes up I'll find their focal length s...
What I want to know is how far apart the objective lens and eyepiece should be kept for clear and maximum magnification...
I just need a formula or some way to calculate the dist between them.
Also , how to fix the inverted image that will be formed by using the two lenses I have...I know I'll have to use another lens but again how far should it be placed and of what focal length should it be.
I want an erect image..
Assume I have two lenses of focal length F , one of 2F...if you need...
Please correct me if I'm wrong...anywhere..
I'm willing to get any other materials I might need ..
As long as the focal point of the object lens is inside the focal distance of the eyepiece (distance between lenses is less than the sum of the two focal lengths: distance < 3F) you will get magnification. The magnification itself will depend upon how much smaller.
The magnification of a simple (astronomical) telescope, using two lenses is equal to the ratio of their focal lengths. The lens with the longer focal length is used as the 'objective' and the shorter is used for the 'eyepiece'. Most random 'magnifying glasses' will tent to have similar focal lengths so the magnification won't be all that special but you will be able to prove the point easily as long as the focal lengths are at all different.
Btw, you don't need to wait for the sun. A distant light bulb will be quite sufficient to find the approximate focal length.
Remember that the distance will change if you are looking at terrestrial objects because of the shift in the focus.
You may be better off using a mirror set at a 45 degree angle, positioned between the objective and the eyepiece if you have one.
You need the lenses to be separated by the sum of their focal lengths (adjust for focus) but you can do nothing to change the magnification using just two elements.
A single mirror will not restore the image to what you want - it will be laterally inverted. Binoculars use a pair of prisms to invert the image twice so that writing appears correct.
Have you Googled "Simple Telescope" Images yet?
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Thread 'Nonlinear rubberband type thing - "k" dropping fast as it is stretched'
What materials can I try in order to get a curve of displacement versus force that looks somewhat like this.. (of course, there would be a small kink around the origin where the ends of the rubberband are closer together than its length, which is not shown here). I am looking for something that will last at least 100 stretch cycles and is not messy, so for example liquid based colloidal stuff won't be suitable. Is there something one can whip up using silicone and some additive, say? Or...
