rod in freefall
by aaaa202
Tags: freefall
aaaa202
aaaa202 is offline
#1
Nov22-12, 03:25 AM
P: 995
This has been brought up numerous times but I don't really understand it. Consider a rod in freefall.
If you put your coordinate frame in the center of mass of the rod, there will be no torque around it and the rod as a whole will follow a straightline down. But now put a coordinate frame on one of the end points. Apart from the gravity pulling down on the rod as a whole, there will now be a net torque on the rod (because gravity acts in the center of mass).
What goes wrong with this picture, because clearly the rod doesn't rotate!
Phys.Org News Partner Physics news on Phys.org
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Mapping the road to quantum gravity
Chameleon crystals could enable active camouflage (w/ video)
chill_factor
chill_factor is offline
#2
Nov22-12, 03:28 AM
P: 887
Quote Quote by aaaa202 View Post
the rod is a rigid body. the other side of the rod also has an equal torque, and due to rigidity, will be in the opposite direction.
Doc Al
Doc Al is offline
#3
Nov22-12, 03:38 AM
Mentor
Doc Al's Avatar
P: 40,905
The problem is that you are you using an accelerating point as your 'pivot'. Torque about such an accelerating point does not simply equal the rate of change of angular momentum, unless that point happens to be the center of mass.
See my post in this thread: http://www.physicsforums.com/showthread.php?p=4097976
Doc Al
Doc Al is offline
#4
Nov22-12, 03:39 AM
Mentor
Doc Al's Avatar
P: 40,905
rod in freefall
Quote Quote by chill_factor View Post
The only external force acting on the rod is gravity.
A.T.
A.T. is offline
#5
Nov22-12, 06:42 AM
P: 3,552
In an accelerated frame that falls with the rod, there is an inertial force upwards:
http://en.wikipedia.org/wiki/Fictiti..._straight_line
The inertial force cancels gravity at any point of the rod. Regardless if the origin is in the center or the end: There is no net force on any part of the rod in such a frame, and thus no torque.
Doc Al
Doc Al is offline
#6
Nov22-12, 06:57 AM
Mentor
Doc Al's Avatar
P: 40,905
Quote Quote by A.T. View Post
That's a good way to look at it (and probably more straightforward).
The extra terms (beyond the torque due to external forces) you get when you calculate dL/dt about an accelerating point are equivalent to introducing that inertial force.
mfb
mfb is offline
#7
Nov22-12, 08:33 AM
Mentor
P: 10,853
In the frame of one of the ends, the rod gains angular momentum - by falling linearly to the floor.
The torque is present, and required for a linear motion downwards in this frame.
Doc Al
Doc Al is offline
#8
Nov22-12, 08:44 AM
Mentor
Doc Al's Avatar
P: 40,905
Quote Quote by mfb View Post
Viewed from an inertial frame, the rod gains angular momentum. But in the accelerating frame of one of its ends, it does not.
D H
D H is offline
#9
Nov23-12, 02:12 AM
Mentor
P: 14,476
Yes, there is a torque. It's the same phenomenon that causes spaghettification. Taking advantage of, or otherwise dealing with, gravity gradient torque is an important concept for satellites in low Earth orbit.
K^2
K^2 is offline
#10
Nov23-12, 03:00 AM
Sci Advisor
P: 2,470
Quote Quote by D H View Post
Problem assumes uniform gravitational field. There are no tidal forces. Doc Al and A.T. have it covered from both perspectives.
Register to reply
Related Discussions
Error measurement in time of flight tests Classical Physics 4
Freefall!!! Introductory Physics Homework 2
motion under gravity General Physics 6
Freefall Introductory Physics Homework 3
