Calculating Boiler Capacity and Steam Properties
In summary, the conversation discusses the process of a steam turbine connected to a generator in an electric generating plant. The task is to calculate the amount of water needed to fill a 5.0 m^3 boiler with steam at 50 atm and 400 degrees Celsius, as well as the volume of the steam after it exits the turbine at 2.0 atm and 150 degrees Celsius. The suggested approach is to use steam tables and find the specific volume of the steam to determine the mass and volume of the water vapor. The use of the ideal gas law is not recommended.
lindsey4
An electric generating plant boils water to produce high pressure steam. The steam spins a turbine that is connected to the generator.
a) how many liters of water must be boiled to fill a 5.0 m^3 boiler with steam at 50 atm and 400 degrees Celsius.
b) The steam has dropped to 2.0 atm at 150 degrees Celsius as it exits the turbine. How much volume does it now occupy?
pv=nRT (not sure...but think you have to use some sort of ideal gas equation)
Can you somehow find moles of the steam and then convert that to the liquid state somehow... do you use stochiometry?
I'd assume an ideal gas unless you've been told to do otherwise.
If you can calculate the number of moles of water you need, then you can calculate the mass of water you need. Then just look up the density of water to get the volume.
Do not use the ideal gas law. You are dealing with superheated water vapor. Use steam tables and find the specific volume of the steam at the indicated pressure and temperature. Since you know the volume you can determine the mass of the water vapor.
My advice would be to follow RTW69's advice, not mine.
I would like to clarify that the ideal gas equation (pv=nRT) is not applicable in this scenario as steam is not an ideal gas. Instead, we can use the steam tables or steam property calculator to determine the properties of steam at different conditions.
a) To calculate the amount of water needed to fill a 5.0 m^3 boiler with steam at 50 atm and 400 degrees Celsius, we need to use the steam tables or steam property calculator to determine the specific volume of steam at these conditions. Once we have the specific volume (in m^3/kg), we can then calculate the mass of steam needed to fill the boiler using the formula: volume = mass/specific volume. From there, we can convert the mass to liters using the density of water.
b) To determine the volume of steam at 2.0 atm and 150 degrees Celsius, we can use the same method as above. We would first calculate the specific volume of steam at these conditions and then use the formula: volume = mass x specific volume. From there, we can convert the mass to liters using the density of water.
In summary, to accurately calculate boiler capacity and steam properties, it is important to use the appropriate equations and tools, such as steam tables or steam property calculators, rather than assuming steam behaves like an ideal gas.
1. What is boiler capacity and how is it calculated?
Boiler capacity refers to the amount of steam that a boiler can produce in a given period of time. It is typically measured in terms of pounds of steam per hour (lb/hr) or BTUs per hour (BTU/hr). Boiler capacity is calculated by taking into consideration factors such as the boiler's heat transfer rate, efficiency, and steam properties.
2. What are the key factors that affect boiler capacity?
The key factors that affect boiler capacity include steam pressure, steam temperature, and fuel type. The higher the steam pressure and temperature, the greater the boiler capacity. Additionally, the type of fuel used in the boiler can also impact its capacity, as different fuels have different heat values.
3. What are the steam properties that need to be considered when calculating boiler capacity?
The steam properties that need to be considered when calculating boiler capacity include steam pressure, steam temperature, and specific enthalpy. These properties are used to determine the amount of heat energy required to produce a certain amount of steam, which is then used to calculate the boiler's capacity.
4. How can I determine the boiler capacity required for my specific needs?
The boiler capacity required for your specific needs can be determined by considering factors such as the amount of steam needed, the required pressure and temperature of the steam, and the type of fuel that will be used. These factors can then be used to calculate the appropriate boiler capacity that will meet your needs.
5. Can boiler capacity be increased or decreased?
Yes, boiler capacity can be increased or decreased depending on the specific needs of the user. This can be achieved through various methods such as changing the boiler's heat transfer rate, adjusting the fuel input, or modifying the steam properties. However, it is important to consult a professional before making any changes to a boiler's capacity to ensure safety and efficiency.
