Difficult indefinite integral (mix of integration by parts and/or substitution)
In summary, the OP was not able to solve an indefinite integral and was looking for help. Substituting w=x+1 for the ln(x) term in the denominator of the equation seemed to help, but the problem was that the denominator was cubed and not simply raised to a power. Partial fractions were used to simplify the equation.
hoeranski
I do not know how to solve the following indefinite integral.
I personally think it is very difficult and would appreciate it had
someone can explain it step by step?
This integral must been solved by mix of integration by parts and/or substitution
but I had no luck to get the answer.
Hint: look at the numerator (without the ln(x) term) and look at the denominator.
Doesn't it look like a u and du perhaps?
Have you tried any substitutions and/or integrated by parts yet?
The substitution w = x+1 might make SteamKing's hint easier to follow.
The substitution w = x+1 is really not helpful here, IMO.
However, if you take the derivative of the denominator, and then compare it to (x+1), you are getting warm.
Dick said:
You forgot to cube the denominator.
I can't see a cube on the denominator in the image that the OP posted. Maybe it's something to do with the way the image is rendered in my browser (Chrome). :confused: (Yes, I tried zooming, etc.)
I even tried using Firefox, to no avail.
What I'm seeing is:
[tex]\frac{(x+1)\ln(x)}{(x^2 + 2x + 10)}[/tex]
I don't even see the integral sign, element of integration, etc. (if they're there in the original image).
With the cube, it becomes easy.
Curious3141 said:
I can't see a cube on the denominator in the image that the OP posted. Maybe it's something to do with the way the image is rendered in my browser. :confused: (Yes, I tried zooming, etc.)
What I'm seeing is:
Yeah. Your image is getting cut-off. I'm using Firefox on Ubuntu and it looks fine all the way to the dx to me.
My first thought was to let [itex]u= x^2+ 2x+ 10[/itex], the denominator, since its derivative is [itex]2x+ 2= 2(x+ 1)[/itex], but, of course, the "ln(x)" messes that up.
Okay so my second thought was to let [itex]u= ln(x)[/itex] so that [itex]du= (1/x)dx[/itex], [itex]xdu= e^u du= dx[/itex]. Since [itex]x= e^u[/itex], the integral becomes
[tex]\int \frac{e^u+1}{e^{2u}+ 2e^u+ 1}e^udu= \int \frac{e^2u+ e^u}{e^{2u}+ 2e^u+ 1}du[/tex]
and now try the substitution [itex]v= e^{2u}+ 2e^{u}+ 1[/itex].
The problem in the OP has the denominator cubed, and the constant term in the denominator is 10 and not 1.
The substitution x = e^u transforms the numerator to u* (Exp(u) + 1), and of course dx= Exp(u) du. Therefore, the numerator becomes:
(Exp(2u) + Exp(u))*u du.
I was waiting to see if OP would return. That's looking doubtful.
It seems to me that a substitution of w = x+1, followed by integration by parts is the way to go. This substitution does look helpful. (I've tried it both ways.) After this it appears that partial fraction decomposition is in order. WolframAlpha shows a result with 5 terms which is consistent with all of this.
Didn't the OP say we needed integration by parts?
[itex]\int \frac{(x+1)ln(x)}{(x^2 + 2x + 10)^3} \ dx= \int ln(x) \frac{(x+1)}{(x^2 + 2x + 10)^3} \ dx[/itex]. Let u = ln(x) (implying du = dx/x) and dv = (x+1)/((x^2 + 2x + 10)^3) dx. Thus, [itex]v = \int \frac{(x+1)}{(x^2 + 2x + 10)^3} dx= \frac{-1}{4(x^2 + 2x + 10)^2}[/itex]
[itex]\int ln(x) \frac{(x+1)}{(x^2 + 2x + 10)^3} \ dx = \frac{-ln(x)}{4(x^2 + 2x + 10)^2} - \int \frac{-1}{4(x^2 + 2x + 10)^2} \frac{dx}{x} \\
\frac{-ln(x)}{4(x^2 + 2x + 10)^2} - \int \frac{-1}{4x(x^2 + 2x + 10)^2} \ dx \rightarrow \frac{-ln(x)}{4(x^2 + 2x + 10)^2} - \frac{\frac{30(x-8)}{x^2 +2x + 10}+28 arctan\frac{(x+1)}{3}-54 ln(x)+27 ln(x^2 + 2x + 10)}{21600}[/itex]
I used the "\rightarrow" to indicate skipping the dreary use of partial fractions. I think you guys can take it from here...
It said and/or.
With the possible exception of the OP poster, I think we already did. :wink:. (I've never been sure whether 'OP' stands for Original Post or Original Poster, but I've always taken it to be the former.)
1. What is a difficult indefinite integral?
A difficult indefinite integral is an integral that cannot be easily solved using basic integration techniques, such as integration by parts or substitution. It may involve complex functions or involve a combination of multiple integration techniques.
2. How do I approach solving a difficult indefinite integral?
The first step in solving a difficult indefinite integral is to try to simplify the integrand by using algebraic manipulations or trigonometric identities. If this is not possible, then integration by parts or substitution can be used. It may also be helpful to look for patterns or use advanced integration techniques, such as partial fractions or trigonometric substitution.
3. What is integration by parts?
Integration by parts is a technique used to evaluate integrals of the form ∫u(x)v'(x) dx. It involves choosing one function to be u(x) and its derivative to be v'(x), and then using the formula ∫u(x)v'(x) dx = u(x)v(x) - ∫v(x)u'(x) dx to simplify the integral.
4. What is substitution in integration?
Substitution in integration is a technique used to evaluate integrals of the form ∫f(g(x))g'(x) dx. It involves substituting a new variable, u, for g(x) and then using the formula ∫f(g(x))g'(x) dx = ∫f(u) du to simplify the integral. This is often useful when the integrand contains a nested function or a complicated expression.
5. Can a difficult indefinite integral always be solved?
No, not all difficult indefinite integrals can be solved exactly. In some cases, the integral may not have a closed-form solution, meaning it cannot be expressed using a finite number of standard mathematical operations and functions. In these cases, numerical methods may be used to approximate the solution.
