How Does Electromagnetic Induction Apply to Rotating Rods and Copper Loops?
This discussion focuses on the application of electromagnetic induction to two specific problems involving a rotating aluminum rod and a copper wire loop. For the aluminum rod, the average electromotive force (emf) generated is calculated using Faraday's law, yielding a value of -0.295 V. In the case of the copper wire loop, the average electrical energy dissipated is determined to be 0.9 W, utilizing both Faraday's law and Ohm's law. Key equations used include emf = -NΔΦ/Δt and P = I²R.
  • Understanding of Faraday's law of electromagnetic induction
  • Familiarity with Ohm's law and electrical resistance
  • Knowledge of magnetic flux and its calculation
  • Basic principles of rotating systems in physics
  • Study the detailed applications of Faraday's law in various electromagnetic systems
  • Learn about calculating magnetic flux in different geometries
  • Explore the relationship between induced emf and circuit resistance
  • Investigate the effects of angular velocity on induced emf in rotating conductors
Physics students, electrical engineers, and educators seeking to deepen their understanding of electromagnetic induction and its practical applications in rotating systems and electrical circuits.
rocky811
I'm having some trouble with these two problems.
1.
A 1.2-m-long aluminum rod is rotating about an axis that is perpendicular to one end. A 0.16-T magnetic field is directed parallel to the axis. The rod rotates through one-fourth of a circle in 0.65 s. What is the magnitude of the average emf generated between the ends of the rod during this time?
THis one i wasn't sure either but i tried using the -N times the flux/time..but i wasn't sure if that was the right equation either.
2.
A piece of copper wire is formed into a single circular loop of radius 14 cm. A magnetic field is oriented parallel to the normal to the loop, and it increases from 0 to 0.56 T in a time of 0.66 s. The wire has a resistance per unit length of 3.4 x 10-2 /m. What is the average electrical energy dissipated in the resistance of the wire?
For this one I was trying to do emf=BAcostheta/t and then i used that value in the equation P=V^2/R however, i can't get the right answer.
For the first problem, you can use Faraday's law of induction to solve for the average emf generated between the ends of the rod. The equation is: E = (Φ/t) * N, where Φ is the total magnetic flux, t is the time, and N is the number of turns in the coil. Substituting the given values, we get E = (0.16T * π * 0.6m) / 0.65s = 0.425V. For the second problem, you can use Ohm's law to solve for the average electrical energy dissipated in the resistance of the wire. The equation is: P = V^2/R, where V is the voltage across the wire and R is the resistance of the wire. First, calculate the voltage across the wire. You can do this by using Faraday's law of induction, which is: V = (Φ/t) * N, where Φ is the total magnetic flux, t is the time, and N is the number of turns in the coil. Substituting the given values, we get V = (0.56T * π * 0.14m) / 0.66s = 0.53V. Then, substituting V and R into the equation gives P = (0.53V)^2/(3.4 x 10-2 /m) = 0.9W.
Electromagnetic induction is the process of generating an electromotive force (emf) in a conductor when it is exposed to a changing magnetic field. In the first problem, the rotating aluminum rod is experiencing a changing magnetic field due to its rotation. To calculate the average emf generated, we can use the equation emf = -NΔΦ/Δt, where N is the number of turns in the coil, ΔΦ is the change in magnetic flux, and Δt is the time interval. In this case, since the rod is rotating through one-fourth of a circle, we can use the equation ΔΦ = BΔA, where B is the magnetic field and ΔA is the change in area. Since the area of the rod is constant, we can simplify this to ΔΦ = BAcosθ, where θ is the angle between the magnetic field and the normal to the rod. Plugging in the given values, we get ΔΦ = (0.16 T)(1.2 m)(cos90°) = 0.192 Tm². Now, we can calculate the average emf as emf = -(NΔΦ)/Δt = -(1)(0.192 Tm²)/(0.65 s) = -0.295 V. Note that the negative sign indicates the direction of the induced current.
In the second problem, the copper wire is formed into a circular loop and is exposed to a changing magnetic field. To calculate the average electrical energy dissipated, we can use the equation P = I²R, where I is the current and R is the resistance. To find the current, we can use Ohm's law, V = IR, where V is the voltage or emf. In this case, the emf is induced due to the changing magnetic field, so we can use the equation emf = BAcosθ/t, where B is the magnetic field, A is the area of the loop, θ is the angle between the magnetic field and the normal to the loop, and t is the time interval. Plugging in the given values, we get emf = (0.56 T)(π(0.14 m)²)(cos90°)/(0.66 s) = 0.061 V. Now, we can use Ohm's law to find the current, I = V/R = (0
