New Reply
drop force
Share Thread Thread Tools
Mar20-13, 04:16 PM   #1
drop force
im trying to calculate the drop force of falling object. we do drop test at my work and believe the figures are wrong. we drop a 24.75lb weight from different heigths to check parts . they have it now set that dropping the given weight from 1 ft only produces 24.75 ft/lb force and they add 24.75 for each foot after that. I came up with around 74.86ft/lb at 1 foot. 24.75 seems low at 1 foot. any help is appreciated. brandon
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Mar20-13, 04:24 PM   #2
Mentor
Quote by rampage11 View Post
Are you sure it's not 24.75 ft-lbs of kinetic energy per foot drop, not force? That would make sense.
Mar20-13, 04:38 PM   #3
the parts has to hold 130lb of sheer force
Mar20-13, 06:52 PM   #4
Math 2012
Recognitions:
drop force
The numbers in the OP don't make any seise to me. The force you apply during the impact depends very much on the deceleration of the mass, as well as the height you drop it from.
For an impact between two stiff and "hard" objects, the maximum impact force could be hundreds or thousands of times the weight of the dropped object.
Aside from that, the unit ft/lb isn't a "force" - maybe you meant ft-lbf, which is the energy of the dropped object, as Doc Al said.
Mar20-13, 07:12 PM   #5
ft-lbf is what I meant..the part moves about 1/2 inch at impact
Mar20-13, 08:25 PM   #6
Mentor
Potential energy then is weight times height.
Mar20-13, 08:58 PM   #7
130 psi of shear force from drop test is what our prints say
Mar20-13, 11:18 PM   #8
It is impossible to predict the force (average or peak) during the impact without knowing what material you are dropping the weight onto. I think you said that your specimen deformed a maximum of 1/2 inch during the test? That could be useful information, if we knew the area and thickness of the specimen, and if we knew how elastic the collision is.
Mar21-13, 05:33 AM   #9
Mentor
The test sounds a little like a charpy impact test, which measures fracture energy:
http://en.wikipedia.org/wiki/Charpy_impact_test
But I'm sorry, there is no such term as "drop force" used in engineering.
Mar23-13, 05:17 AM   #10
Hey,
Since the object is having sudden impact, the impact force will be more twice the load. The general equation of the impact load is : W+[itex]\sqrt{(W^{2} + 2AWhE/L)}[/itex]
where,
W - weight of the object
A - surface area of impact
L- Length of the body perpendicular to surface of impact
h- height from which body is dropped
E- Modulus of elasticity of the object
Just put in the material and geometrical properties..
So the value comes out to be greater than twice the weight of the body. So 74.86 seems kinda ok. But I don't know the dimensions or the material dropped. So I can't tell.. If you want, just give me the details.. I'll try to work out the values
Mar23-13, 10:33 AM   #11
ill have to remeasure it..but I believe its 4'' round stock steel..12'' long dropped from 1 ft increments..weighs 24.73lb
Mar23-13, 12:07 PM   #12
Is the specimen being dropped onto something "rigid?" Or are you dropping something "rigid" onto the specimen? Your specimen is 4" diameter steel?
Mar25-13, 07:23 PM   #13
rigid..dropping specimen onto a 5/8 steel rod in 1ft increments
New Reply
Thread Tools
Similar Threads for: drop force
Thread Forum Replies
Finding impact force on Steel ball drop test Classical Physics 6
Impact force on a bike off a 6 foot drop? General Physics 2
Impact force exerted on a rolling wheel drop from a height Introductory Physics Homework 1
Is 1/R^3 descriptive of magnetic force drop off? Classical Physics 18
Force for mass drop? Introductory Physics Homework 12
