Finding the Laplace Transformation of a Piecewise Function
Northbysouth
Obtain the Laplace transformation of the function defined by
f(t) = 0 t<0
= t2e-at t>=0
I'm a little unsure of what I'm doing here, so bear with me.
L {t2e-at} = ∫inf0 t2e-at dt
= ∫0inf t2e-(a+s)tdt
How do I integrate this? I tried using my TI-89 but it told me it is undefined. Any help would be greatly appreciated.
EDIT: The complete solution is required, which I think means I can't just take it out of the Laplace tables
f(t) = 0 t<0
= t2e-at t>=0
First of all: never, never write what you did above, which was
\int_0^{\infty} t^2 e^{-at} \, dt = \int_0^{\infty} t^2 e^{-(a+s)t} \, dt.
This is only true if s= 0.
Anyway, for your final (correct) integral, change variables from t to x = (a+s)t (assuming s > -a).
I strongly recommend that you put away the TI-89 until after you have learned how to do these problems, or at least restrict its use to numerical computation.
Sorry, I missed out a part.
There should have been an e-st
But I don't understand your point about changing the variable from t to x. Could you explain further please?
I assume you have taken integration already. If so, you already studied change-of-variable methods (or so I hope).
If you have not done integration yet you would need a longer explanation than I am prepared to give here: we would need to go over material that takes several weeks to present in coursework! However, such information is widely available in books and on-line.
Yes, it's just integration. But the trick you really need to handle the t^2 factor is integration by parts. By all means, review integration.
It's much simpler to evaluate
\tilde{g}(s)=\int_0^{\infty} \mathrm{d} t \exp[-(a+s) t]
and then taking the 2nd derivative wrt. s. It's very easy to see that
\tilde{f}(x)=\tilde{g}&#039;&#039;(s).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
