Calculating voltage drops in cables with vectors?
To calculate voltage drops in a 3x400VAC system vectorially, one approach involves using the formula ΔU.conductor = I.1*Z.cable1 + I.2*Z.cable2, followed by determining the new voltage using U.new = U.nominal - ΔU.phase, where ΔU.phase = U.conductor*√3. The discussion highlights a discrepancy where the calculated voltage drop results in a higher voltage, particularly during motor startup, which may stem from misunderstandings in power factor calculations. The importance of separating vector components into their X and Y parts is emphasized for accurate vector addition. Understanding the relationship between sine, cosine, and vector quantities is crucial for resolving these calculations effectively.
EVriderDK
Hey.
If i Have a 3x400VAC system, and I want to calculate the voltage drop over the cable "vectorially" - or what you call it :) - how do I do this?
U.nominal=400V
I have tried this method:
\DeltaU.conductor=I.1*Z.cable1+I.2*Z.cable2+etc. and then I will have to find the new voltage ->
\DeltaU.phase=U.conductor*\sqrt{3}
U.new=U.nominal-\DeltaU.phase
When I'm calculating this with angles, I actually get a higher voltage, after the voltage drop :D
The voltage drop is cause by a electrical motor starting.
In school we learn it this way:
\varphi.motor=80 degrees
U.new=U.nominal-\sqrt{3}*I1*Length.cable1*(R.cable1*cos\varphi+X.cable1*sin\varphi)+\sqrt{3}*I2*Length.cable2(R.cable2*cos\varphi+X.cable2*sin\varphi)+etc.
But that is not with vectors.
Hope you understand?
Thanks in advance.
I'm pretty weak with respect to power factor stuff, but sin and cos are intimately tied to the vector quantities.
Acosβ represents the X component and Asinβ the Y component of a vector of magnitude A at angle β (usually called real and imaginary parts).
If you want to add two vectors you can add their respective X parts and Y parts to determine the new X and Y parts of the resulting vector.
You can probably go through the equations you posted and see where the vector math is happening.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
