Simple max shaft torque calculation
To calculate the maximum torque for a 2" diameter shaft rotating at 8 RPM with a 60" diameter, 6500 lb cylinder, first determine the rotational moment of inertia of the cylinder. The torque required to start or stop the shaft depends on this inertia and can be calculated using angular acceleration formulas. If the cylinder is offset by 2", an additional torque from the weight times the moment arm must be included. The peak torque on the brakes or gearbox is what needs to be evaluated, ignoring variations in torque amplitude. Understanding these calculations is crucial for selecting an appropriate brake and gear reducer.
AQUAPOP
Hello.
I'm trying to add a mechanical (pneumatic or electrical) brake to a shaft.
I have a 2" diameter shaft rotating at 8 rpm's max.
The shaft has and 60" diameter, 6500lb. cylinder attached to it axially.
How do I calculate the maximum torque of the shaft?
Thanks in advance,
Frank
Rotating shafts generally fail from fatigue. Do you know how to calculate stresses and predict fatigue?
At this point I'm not really concerned with the shaft failing.
I had a grossly undersized gear reducer fail a few times on this application,
so I'm trying to add a brake, and then find a more appropriate gear reducer.
thanks for the quick reply. :)
Sorry, I think I get you now. You're trying to figure out how much torque this 60" diameter, 6500 pound cylinder requires to stop or start it moving at 8 RPM? If that's correct, do you have dimensions on it and do you know how to calculate the rotational moment of inertia? I presume also that there are rolling element bearings supporting this shaft so that friction can be neglected?
You are correct.
I have steel cylinders (heat exchangers) on a horizontal rotisserie.
Both ends are supported on shafts in bearings.
The cylinders vary in diameter and length, and internal structure.
Another wrinkle is because of varying internal structure some rotate 2" offset from their center of gravity.
The torque required to start or stop the shaft is a function of it's rotational inertia. Imagine a car and you have to push it. The lighter the car is, the easier it is to accelerate it from a dead stop by pushing it. The torsional analogue of that is what you're interested in. Just as the car has some mass which resists accelerating, the shaft with the attached cylinder has rotational resistance due to its rotational inertia. You can calculate the rotational moment of inertia using standard formulas for simple shapes as shown here: https://webspace.utexas.edu/cokerwr/www/index.html/RI.htm
or if you can do the math, try a more advanced calculation following the equations provided by Wikipedia here:
http://en.wikipedia.org/wiki/Moment_of_inertia#Example_calculation_of_moment_of_inertia
Once you know the rotational inertia, and you want to find the torque required to change the rotational speed, use the formula for angular acceleration,
http://en.wikipedia.org/wiki/Angular_acceleration
http://hyperphysics.phy-astr.gsu.edu/hbase/n2r.html
http://theory.uwinnipeg.ca/physics/rot/node5.html
I've provided a few different sites but they all say the same thing. Note that angular acceleration is simply the change in angular rotational rate divided by the time taken to change, ie: [PLAIN]http://upload.wikimedia.org/math/f/d/9/fd97cb711276815954e9824fabee8baf.png. So for example, if you want to accelerate the cylinder from 0 to 8 RPM in 1 second, that's an acceleration rate of 8/60*2*pi*radians/s2. If it takes longer or shorter than 1 second, divide by the number of seconds.
For the torque exerted by the cylinder being off center by 2", just add an additional torque of the cylinder weight times this 2" moment arm (ie: 6500 lb x 2" = 13,000 lb in). The amplitude of that torque is obviously going to vary sinusoidally but for your purposes (trying to determine the peak torque on the brakes or gearbox) you really don't care about that.
Likes 2 people
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
