Electron accelerated though constant E field
The discussion focuses on calculating the momentum and kinetic energy of an electron in a constant electric field of 1000 V/m, both in the lab frame and in a rocket moving at 0.99c. Participants suggest starting by plotting the electron's position over time and applying Lorentz transformations to convert coordinates to the rocket's frame. The next steps involve determining the velocity in the rocket's frame and subsequently calculating the kinetic energy. This approach emphasizes the importance of understanding relativistic effects on the electron's motion. Overall, the thread seeks guidance on tackling the physics problem effectively.
deadscientist
Suppose an electron is initially at rest in a constant E field of 1000 V/m as measured in the lab. Determine the electrons momentum and kinetic energy as a function of time a) in the lab frame b) in the frame of.a rocket moving at .99c in the direction of the electric field. Not quite sure how to approach the problem any suggestions would be greatly appreciated thank you.
Why not start by plotting position as a function of time? What would that graph look like?
The next step would be to apply the Lorentz transformation to the x and t coordinates to get the x' and t' coordinates in rocket's frame of reference.
Then work out v' in the rocket's frame of reference using those x' and t' coordinates. Then work out v^2 to find kinetic energy.
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
