Coefficient of Static Fraction
The coefficient of static friction (μ_s) is often treated as a constant in tables, representing the ratio of the maximum static friction force (F_s) to the normal reaction force (R). While the friction force increases with applied force, μ_s specifically refers to the limiting friction at which motion begins. This means μ_s is effectively the coefficient of limiting friction, indicating the threshold before sliding occurs. Understanding this distinction clarifies why μ_s is presented as a constant despite variations in applied force. The concept is crucial for accurately interpreting friction in practical applications.
poonintoon
Please could somebody explain how the coefficient of static friction can be quoted as a constant in tables etc?
\mu_s = F_s/ R
In most cases the reaction force is constant but as I push the box harder the friction force increases.
Is \mu_s actually the coefficient of limiting friction? Or am I totally misunderstanding?
Yes.
Likes 1 person
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
10K
