Understanding Glass: Is it a Solid or Liquid?
  • Context: High School
  • Thread starter Thread starter Igid
    Liquid
The discussion revolves around the classification of materials such as gels, creams, pastes, and glass in terms of their states of matter—specifically whether they are solids, liquids, or a combination of both. Participants explore definitions, characteristics, and examples of these materials, aiming to clarify their properties for a primary school audience.
  • Some participants suggest that gels, creams, and pastes are mixtures of solids and liquids, while others argue that they can be classified as solids or liquids depending on context.
  • A participant defines solids and liquids based on their physical properties, noting that solids resist deformation and have a definite shape, while liquids take the shape of their container.
  • There is a proposal that the term "semisolid" may be appropriate for materials like gels and creams, indicating they exhibit characteristics of both solids and liquids.
  • Some participants assert that glass flows over time and can exert pressure, leading to the classification of glass as an amorphous solid, while others maintain it is a solid despite its slow flow.
  • One participant references a historical myth regarding stained glass windows, arguing that the thickness variation in old glass is not due to flow but rather the manufacturing process.
  • Discussion includes the nature of mixtures, with examples like concrete being described as a combination of solids and liquids, raising questions about how to classify heterogeneous versus homogeneous mixtures.
  • Aerogel is introduced as a material that challenges traditional classifications, being described as more solid than typical gels and exhibiting unique properties.
Participants express multiple competing views regarding the classification of gels, creams, pastes, and glass, indicating that the discussion remains unresolved with no consensus reached.
Definitions of states of matter are debated, with some participants noting the lack of clarity in distinguishing between solids and liquids, particularly for materials that exhibit properties of both. The discussion also touches on historical interpretations and the implications of manufacturing processes on material properties.
Igid
Please help me in this. Are gel, cream and paste liquids? I'm getting the answer for primary school students. So, please help me explaining in simple way. Thank you!
Igid
I think they're all solids. cream might be a liquid.
Look at the definition of liquid :)
Igid
I think they are mixtures of both solids and liquids. For the most part the things you mentioned will evaporate or dry up when exposed to the air and leave behind some solids.
A solid is a state of matter, characterized by a definite volume and a definite shape (it resists deformation). Within a solid, atoms/molecules are relatively close together, or "rigid"; however, this does not prevent the solid from becoming deformed or compressed. In the solid phase of matter, atoms have a fixed spatial ordering; because all matter has some kinetic energy, the atoms in even the most rigid solid move slightly, but this movement is "invisible".
A liquid is a phase of matter and a fluid whose volume is fixed under conditions of constant temperature and pressure, and, whose shape is usually determined by the container it fills. Furthermore, liquids exert pressure on the sides of a container as well as on anything within the liquid itself; this pressure is transmitted undiminished in all directions.
Gel is a liquid, cream (like milk) is a liquid, cream (like ointment) is a liquid, paste is a liquid. For those who say othersise, pour or squeeze them into a small cup, and see if they spread out and form into the shape of their container.
Try semisolid !
The boundary between a solid and a liquid is not well defined (whether in terms of viscosity or the ability to support shear stress), and things living in the grey area can safely be called semisolids.
Mk, your definitions of a liquid lack any mention of time scales. A piece of glass, given sufficient time, will flow to fill a container and exert pressure on the side walls. But while some will call glass a liquid, most still like to think of it as a solid.
Solid, liquid and gas are the three major distinctions of the state of matter. However there are some materials which may exhibit charateristics of two states, such as gels, creams or pastes.
As Gokul mentioned, "semi-solid" may be appropriate, but also perhaps semi-liquid. Glass is effectively an amorphous solid, i.e. not crystalline lattice structure. Glass actually flows (creeps) but very slowly. Concrete/cement also flow, which has interesting implications for many man-made structures, which should last a long-time.
Gel's are a form of 'colloid'. From Wikipedia:
A gel is an apparently solid, jellylike material formed from a colloidal solution. By weight, gels are mostly liquid, yet they behave like solids. An example is gelatin.
Here are some definitions of colloid.
Wikipedia said:
In general, a colloid or colloidal dispersion, is a two-phase system of matter; small droplets or particles of one substance, the dispersed phase, are dispersed in another, continuous phase forming so called phase colloid. Another type of colloid is called molecular colloid and is formed of macromolecules dispersed in a continuous phase (dispersion medium).
from http://en.wikipedia.org/wiki/Colloid
Schlumberger (oil services company) - http://www.glossary.oilfield.slb.com/Display.cfm?Term=colloid
The is a good book, but hard to find - "Seven States of Matter" by Milton Gottlieb (1966). I read it about 30+ years ago, and it gives a good overview of the states of matter.
are you sure? because old glass was made larger at the bottom anyway, well, according to a historian atleast...
what are these states?
How about aerogel?
Gas? solid?
can you breathe in this areogel? and if so, would you just fall to the bottom or float?
Freshly mixed concrete appears to be a liquid, but it is made up of stone aggregate, cement, sand, and water. It's a mixture at this point of solids and liquid. If you remove a stone from this concrete you will find it to be very much a solid not liquid. In grade school science I remember discussing adding substances together and determining whether they were mixtures or new substances created through a chemical reaction. I think you can only apply the term solid, liquid, or gas to individual groups of the same molecules. Sure you can have 2 liquids in the same glass but its still a mixture.
Lets say we have a glass filled with marbles and water, what would you consider this a solid or liquid...it's a mixture.
Nereid said:
How about aerogel?
Gas? solid?
Aerogel, is much more solid than your typical gooey gel. It shears and it doesn't flow. Also importantly, it is anisotropic over microscopic scales.
This distinction is important for many kinds of gels where you will find that, on setting for long periods, the different components tend to partially separate. But even when invoking the rebuttal based on mixtures, there is sometimes a grey area. The counter-argument often used is that a state can be assigned to a homogeneous mixture but not a heterogeneous one. The grey area : where the crossover happens...
This is a myth that was effectively debunked a couple years ago. The myth was started by someone examining a stained glass window in an old Cathedral in Europe. All the pieces of glass seemed to be thicker at the bottom than the top. The person concluded the glass had flowed over several centuries.
As hexhunter was trying to point out, further examinations of Cathedral stained glass have shown that many windows from the same period have a statistically proper number of pieces that are thicker at the top than the bottom.
All the glass back then was hand blown, and they had no way to regulate the thickness. It is likely that the maker of the window that precipitated this rumor just put all the glass in thick end down for consistency's sake. They can't find any others like it.
Here's a good article on the subject of glass.
Yeah, that's good. Also a good discussion of the larger solid/liquid dichotomy.
Ok I had to look up hetrogeneous :confused: anyway the description for hetrogeneous mixture gave granite as an example. For homogeneous air is used as an exapmle. Both in this case can be assigned a "state". Still if you separate the components (in either mixture) which aren't bound chemically you get individual compounds with individual properties and states. By assigining states to mixtures we are just being incomplete in the description.
zoobyshoe said:
This is a myth that was effectively debunked a couple years ago. ...
Hmmm...didn't know this. Interesting !
But in any case, the existence of creep at STP is well-known and well documented among several solids, including metals like indium.
Let me rephrase. A heterogeneous mixture need not necessarily have a state assigned to it.
But virtually anything you have in reality is a mixture. Show me a pure, isolated element or compound and I'll show you an egg balancing on its tip. By not allowing a 'stat'e to be assigned to a mixture, you are grossly hampering the usefulness it provides to communication.
Yeah. I used to love telling people that glass was a liquid.
Who believed you?
yomamma said:
Who believed you?
Every zoobie I told.
Like that's an achievement...:rolleyes:
maybe i m missing the context ... but glass IS a liquid. a very viscous one and one that requires nonequilibrium statistical mechanical description.
Check out this site and see if you agree or not.
Is glass liquid or solid?
Address:http://math.ucr.edu/home/baez/physics/General/Glass/glass.html Changed:6:32 PM on Thursday, April 24, 2003
The main point, I think, is that glass is not going to slowly take the shape of a container, even after centuries.
Not even in a mere [itex]10^{9}[/itex] centuries ? :eek:
Also see : http://hypertextbook.com/physics/matter/glass/
That site is interesting, Gokul. It asserts that glass is another phase in and of itself: solid, liquid, gas, glass.
edit: and plasma. Musn't forget plasma.
The glass being referred to there is not just the transparent, SiO2 based molecular network material that we make windows out of - it refers to a whole class of materials that exhibit the specified characteristics.
Reading about ceramics, and especially glazes, I've run across the information that many things can undergo "vitrification", before, yes. I hadn't ever come across mention of this as one of the "phases", along with solid, liquid, etc. Are there any other "phases" you humans have been keeping secret from the zoobies?
Yeah - glass is a glass. We also discussed it a little HERE .
  • · Replies 0 ·
