Solution by variation of parameters
In summary, when proving that a method works, you must make the functions u and v satisfy the second condition u`y1+v`y2=0. This simplifies the resulting equation and makes the math easier. When integrating to find a particular solution, the constant resulting from the integration is left out because a particular solution does not contain any arbitrary constants. Requiring A'y_1+ B'y_2= 0 narrows the field and ensures there will not be any second derivatives of A or B in the final equations.
asdf1
734
i'm confused about that method:
1) when proving that method works, why do you have to make u and v satisfy the 2nd condition u`y1+v`y2=0
2) when you're integrating to find yp, why do you leave out the constant that results from the integration?
When you let:
[tex]y=A(x)y_1(x)+B(x)y_2(x)[/tex]
where [itex]y_1(x)[/itex] and [itex]y_2(x)[/itex] are solutions to the homogeneous equation, and you substitute that into:
[tex]y^{''}+p(x)y^{'}+q(x)y=R(x)[/tex]
Letting:
[tex]A^{'}y_1+B^{'}y_2=0[/tex]
reduces the complexity of the resulting equation to the simplified form:
[tex]A^{'}y_1^{'}+B^{'}y_2^{'}=R(x)[/tex]
Technically you could let it be any non-zero function but zero makes the math easier.
As far as ignoring the constants of integration, note you're looking only for a particular solution to the original DE right: homogeneous part+particular part=solution. And a partcular solution does not contain any arbitrary constants.
thank you very much for clearing those things up! :)
Remember that there are, in general, an infinite number of functions
A(x), B(x) such that [tex]y=A(x)y_1(x)+B(x)y_2(x)[/tex]
Requiring that [tex]A'y_1+ B'y_2= 0[/tex]
just "narrows the field" and guaranties that there will not be any second derivatives of A or B in the final equations.
thank you very much! :)
1. What is "Solution by variation of parameters"?
"Solution by variation of parameters" is a method used to find the particular solution of a non-homogeneous linear differential equation. It is based on the idea that the particular solution can be expressed as a linear combination of the solutions of the corresponding homogeneous equation.
2. When is "Solution by variation of parameters" used?
"Solution by variation of parameters" is typically used when the non-homogeneous term in a linear differential equation is not a polynomial, exponential, or trigonometric function. It is also used when the method of undetermined coefficients is not applicable.
3. How does "Solution by variation of parameters" work?
The method of "Solution by variation of parameters" involves finding a particular solution by assuming it can be expressed as a linear combination of the solutions of the corresponding homogeneous equation. The coefficients of this linear combination are then determined by substituting the particular solution and its derivatives into the original differential equation.
4. What are the limitations of "Solution by variation of parameters"?
One limitation of "Solution by variation of parameters" is that it can only be used for linear differential equations. It also requires the homogeneous equation to have known solutions, which may not always be the case. Additionally, the method can become complicated and tedious for higher order differential equations.
5. Are there any alternative methods to "Solution by variation of parameters"?
Yes, there are alternative methods for finding particular solutions of non-homogeneous linear differential equations, such as the method of undetermined coefficients and the Laplace transform method. These methods may be more suitable for certain types of non-homogeneous terms or differential equations.
