-10.5.99 separable eq y'=x^4y^4
  • MHB
  • Thread starter karush
  • Tags
    Separable
In summary, the given separable differential equation is solved by finding the integral of both sides, resulting in the solution for y as $y=-\left[\frac35\left(x^5+c_2\right)\right]^{-1/3}$, with a typo corrected during the process and the loss of the trivial solution y=0.
karush
MHB
3,269
Solve the separable differential equation
$\displaystyle y'=x^4y^4$
Solve for $y$ if possible.
$\displaystyle
y=\frac{{y'}^{(1/4)}}{x}$
Not sure ?
$\frac{dy}{dx}=x^4y^4$
$\frac{1}{y^4}\,dy=x^4\,dx$
$\int\frac{1}{y^4}\,dy=\int x^4\,dx$
$$\frac{dy}{dx}=x^4y^4$$
$$\frac{1}{y^4}\,dy=x^4\,dx$$
$$\int\frac{1}{y^4}\,dy=\int x^4\,dx$$
$$-\frac13y^{-3}=\frac15x^5+c_1$$
$$y^{-3}=-\frac35\left(x^5+c_2\right)$$
$$y=\left[-\frac35\left(x^5+c_2\right)\right]^{-1/3}$$
$$y=-\left[\frac35\left(x^5+c_2\right)\right]^{-1/3}$$
Where does the $-\frac{1}{3}$ inside the $\left[\right]$ come from
It comes from a typo. :eek: It should be $-\frac35$.
During the process of separation of variables (dividing through by $y^4$), the trivial solution:
\(\displaystyle y\equiv0\)
was lost. :)
1. What is a separable equation?
A separable equation is a type of differential equation where the dependent variable and independent variable can be separated into separate functions.
2. What does the notation "y'=" mean in this equation?
The notation "y'=" indicates that the equation is a first-order differential equation, meaning it involves a variable and its first derivative.
3. What is the significance of "-10.5" in this equation?
The value "-10.5" is likely a constant or initial condition in the equation, which is necessary for solving it.
4. How do you solve this equation?
To solve this equation, you would need to use separation of variables, where you rearrange the equation to have all the y terms on one side and all the x terms on the other side. Then, you can integrate both sides to solve for y.
5. What is the practical application of this equation?
This equation may have various practical applications in fields such as physics, chemistry, and engineering, where differential equations are used to model real-world phenomena. However, without context or additional information, it is difficult to determine a specific application for this equation.
  • Calculus
  • Calculus
  • Calculus
