2214.16 Related Rates With Draining Cone
In summary: Water is being drained from a container which has the shape of an inverted right circular cone The container has a radius of $6 in$ at the top and a length of $8 in$ at the bottom. when the water in the container is $6 in$ deep, the surface level is falling at a rate of $0.9 in/sec$ find the rate at which water is being drained from the container.By using the formula for a cone, and substituting in the appropriate values, we can find that the rate of water drainage is 171.76 cubic inch per second.
karush
MHB
3,269
\(\displaystyle
\begin{align*}\displaystyle
V&=\frac{1}{3}\pi r^2 h\\
\frac{6}{8}&=\frac{r}{h}\\
\therefore \, r&=\frac{3}{4}h\\
V&=\frac{9\pi}{16} h^3\\
\frac{dV}{dt}&=\frac{27\pi}{16} h^2 \frac{dh}{dt}\\
\frac{dV}{dt}&=\frac{27\pi}{16}(6^2)(0.9)\\
&=171.76 \frac{in^3}{sec} \\
0r&= 54.675 \pi \frac{in^3}{sec}
\end{align*}
hopefully
Let $R$ be the radius of the conical container, $H$ be its height, $r$ be the radius of the conical volume of water, and $h$ be the height of the volume of water.
By similarity, we know:
\(\displaystyle \frac{R}{H}=\frac{r}{h}\implies r=\frac{hR}{H}\)
The formula for the volume of the water is:
\(\displaystyle V=\frac{1}{3}\pi r^2h=\frac{1}{3}\pi \left(\frac{hR}{H}\right)^2h=\frac{\pi R^2}{3H^2}h^3\)
Differentiate w.r.t time $t$:
\(\displaystyle \d{V}{t}=\frac{\pi R^2}{H^2}h^2\d{h}{t}\)
We are given:
\(\displaystyle R=6\text{ in},\,H=8\text{ in},\,h=6\text{ in},\,\d{h}{t}=-\frac{9}{10}\,\frac{\text{in}}{\text{s}}\)
And so, for this problem, we find:
\(\displaystyle \d{V}{t}=\frac{\pi\left(6\text{ in}\right)^2}{\left(8\text{ in}\right)^2}\left(6\text{ in}\right)^2\left(-\frac{9}{10}\,\frac{\text{in}}{\text{s}}\right)=-\frac{729\pi}{40}\,\frac{\text{in}^3}{\text{s}}\approx -57.3\,\frac{\text{in}^3}{\text{s}}\)
You used the correct formula for a cone, but when you wrote:
\(\displaystyle V=\frac{9\pi}{16}h^3\)
You neglected the 1/3 in the formula...you should have written:
\(\displaystyle V=\frac{3\pi}{16}h^3\)
Other than that minor error, the method you used itself was correct. :)
karush said:
\(\displaystyle
V&=\frac{9\pi}{16} h^3\\\)
According to your first line \(\displaystyle V= \frac{1}{3}\pi r^2h\)
So this should be
\(\displaystyle V= \frac{1}{3}\pi\left(\frac{9}{16}h^2\right)h= \frac{3}{16}h^3\)
\(\displaystyle \frac{dV}{dt}&=\frac{27\pi}{16} h^2 \frac{dh}{dt}\\
\end{align*}
hopefully
1. What is a draining cone and how does it relate to related rates?
A draining cone is a three-dimensional mathematical shape that resembles a cone with a hole at the top. It is used in related rates problems as a real-life application to demonstrate how the rates of change of different variables are related.
2. How is the volume of a draining cone related to its height and radius?
The volume of a draining cone is directly proportional to the square of its height and the cube of its radius. This means that if the height or radius changes, the volume will change at a different rate.
3. How can the related rates be used to calculate the rate of change of the volume of a draining cone?
By using the formula for the volume of a cone and taking the derivative with respect to time, we can calculate the rate of change of volume with respect to time. This allows us to see how the volume changes as the height and radius of the cone change.
4. What other real-life applications can be modeled using related rates with a draining cone?
Related rates with a draining cone can also be used to model the rate of change of the height of a liquid in a conical tank, or the rate of change of the surface area of a balloon as it is being inflated.
5. What are some tips for solving related rates problems involving draining cones?
Some tips for solving related rates problems with draining cones include drawing a diagram, identifying the variables involved, and setting up equations using the relevant formulas. It is also important to pay attention to the units and use the chain rule when taking derivatives.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • Calculus
  • General Math
  • Classical Physics
