How Does the Third Piece's Velocity Compare After the Clay Ball Shatters?
  • Thread starter perfectlovehe
  • Tags
    Ball Clay
In summary, a 6-kg clay ball with a velocity of 22 m/s is thrown at a perpendicular brick wall and shatters into three pieces. The wall exerts a force of 2430 N for 0.1 s. One piece of mass 2 kg travels backward at a velocity of 15 m/s and an angle of 32° above the horizontal, while a second piece of mass 1 kg travels at a velocity of 7 m/s and an angle of 28° below the horizontal. To find the velocity of the third piece, we can use the equation Initial momentum + impulse delivered by the wall = Final momentum. The initial momentum of the ball is 22 kg*m/s in the opposite direction
perfectlovehe
A 6-kg clay ball is thrown directly against a perpendicular brick wall at a velocity of 22 m/s and shatters into three pieces, which all fly backward, as shown in the figure. The wall exerts a force on the ball of 2430 N for 0.1 s. One piece of mass 2 kg travels backward at a velocity of 15 m/s and an angle of 32° above the horizontal. A second piece of mass 1 kg travels at a velocity of 7 m/s and an angle of 28° below the horizontal. What is the velocity of the third piece? (Let up be the +y positive direction and to the right be the +x direction.)
Initial momentum = Final momentum + impulse delvered by the wall.
22 = x + 2430 ? I came out with -2408 and I believe it's incorrect.
I would write it differently:
Initial momentum + impulse delvered by the wall = Final momentum
You'll use this to find the total momentum of all pieces of the ball after the ball shatters.
What's the initial momentum of the ball? What's the impulse? (Be sure to give the correct signs, since momentum is a vector and direction matters.)
Initial momentum is 22m/s and force is 2430 J. So would that be 2452 J? Or is that incorrect?
That's incorrect. One step at a time:
(1) What's the definition of momentum? Calculate the initial momentum of the ball. What direction is the momentum? What sign?
(2) What's the definition of impulse? Calculate the impulse given to the ball. What direction is the impulse? What sign?
I would approach this problem by first identifying the relevant equations and principles that apply to this scenario. The equation for conservation of momentum, which states that the initial momentum of a system is equal to the final momentum of the system, is a key concept here. Additionally, the impulse-momentum theorem, which states that the change in momentum of an object is equal to the impulse delivered to the object, is also relevant.
Using these principles, we can set up the following equation:
Initial momentum = Final momentum + impulse delivered by the wall
The initial momentum of the system is the momentum of the 6-kg clay ball, which is given by its mass (6 kg) multiplied by its initial velocity (22 m/s). This can be represented as 6 kg * 22 m/s = 132 kg*m/s.
The final momentum of the system is the sum of the momenta of the three pieces of the clay ball. We can represent this as:
Final momentum = (2 kg * 15 m/s) + (1 kg * 7 m/s) + (x kg * v3)
where v3 represents the velocity of the third piece, which is what we are trying to find.
The impulse delivered by the wall is given by the force exerted by the wall (2430 N) multiplied by the time (0.1 s) over which the force is applied. This can be represented as 2430 N * 0.1 s = 243 kg*m/s.
Putting all of this together, we can now set up our equation:
132 kg*m/s = (2 kg * 15 m/s) + (1 kg * 7 m/s) + (x kg * v3) + 243 kg*m/s
Simplifying, we get:
132 kg*m/s = 30 kg*m/s + 7 kg*m/s + (x kg * v3) + 243 kg*m/s
Rearranging and solving for v3, we get:
v3 = (132 kg*m/s - 30 kg*m/s - 7 kg*m/s - 243 kg*m/s) / x kg
Substituting in the values given in the problem, we get:
v3 = (132 - 30 - 7 - 243) / x
v3 = -148 / x
Since we do not have enough information to determine the mass of the third piece (x
1. What is the 6G Clay Ball Equation?
The 6G Clay Ball Equation refers to a mathematical formula used to describe the behavior of a clay ball when it is heated in a furnace. It takes into account factors such as the clay's composition, temperature, and time spent in the furnace.
2. How is the 6G Clay Ball Equation used in scientific research?
The 6G Clay Ball Equation is used by scientists to understand and predict the changes that occur in clay when it is subjected to high temperatures. This information is useful in various fields such as materials science, geology, and archeology.
3. What factors influence the outcome of the 6G Clay Ball Equation?
The outcome of the 6G Clay Ball Equation is influenced by several factors, including the type and composition of the clay, the temperature and atmosphere of the furnace, and the time spent in the furnace. Other factors such as pressure and impurities may also play a role.
4. How accurate is the 6G Clay Ball Equation?
The accuracy of the 6G Clay Ball Equation depends on the quality and quantity of data used to develop the formula. In general, it has been found to be a reliable tool for predicting the behavior of clay under high-temperature conditions. However, like any scientific model, it may have limitations and may need to be refined as new data is gathered.
5. Are there real-world applications for the 6G Clay Ball Equation?
Yes, there are many real-world applications for the 6G Clay Ball Equation. For example, it can be used to understand the formation of pottery and other ceramic materials, as well as the processes involved in the production of building materials. It can also be used to study the geological processes that occur when rocks are subjected to high temperatures.
