A bullet through a pendulum.
In summary: I can use this velocity to find momentum of the pendulum and its bullet, and of course the KE of the bullet, as i know the mass and velocity of the bullet after it leaves the pendulum, now the KE of the bullet is both Ek and Ep, as its height is now zero. In summary, the problem involves a 10g bullet hitting and passing through a 2.20kg pendulum target at 300m/s, causing the pendulum to rise to an angle of 15 degrees. The final speed of the bullet is unknown. The equations used to solve the problem include Ek = 1/2MV^2, Ep = MGH, and momentum = MV. The solution involves using conservation of
zaddyzad
149
A 10g bullet moving at 300.m/s hits and passes through a 2.20kg pendulum target. After the impact, the 1.20m long pendulum rises up to an angle of 15 degree, find the final speed of the bullet.
Ek= 1/2MV^2
Ep= MGH
Momentum = MV
I assumed all energy before and after the question will be = because the collision is inelastic, both masses don't stay together. I found the height the pendulum rises by doing 1.2-(1.2Cos15). Then I put everything i knew in EK= Ep + EK
(300^2)*(0.01)*(0.5) = (2.20)(9.8)(0.04) + (0.5)(0.01)(v')^2
When I solve for velocity I get the answer wrong. What am I doing wrong, am I wrong that energy is conserved ?
why are you using 300^2 ? use conservation of linear momentum to get the relationship between the initial and final velocities of the bullet.
I tried solving via energy.
Though when I try solving momentum i get. 300(0.01)=2.2(v)+0.01(v) 2 variables.
well you need BOTH energy and momentum to solve this... since bullet gets stuck inside the pendulum, this is an inelastic collision and kinetic energy is not conserved...
Though the bullet leaves the pendulum, do we still consider this inelastic ?
oh sorry. didn't read the question properly. let me think
Conservation of momentum works regardless of the nature of the collision. The trick here is to figure out how much momentum ended up in the pendulum bob...
well. the collision is still inelastic. use the conservation of energy to get the velocity of the
pendulum immediately after the collision. then use conservation of linear momentum to connect all three velocities
this doesn't work.
And if the collision is still inelastic you can't "use the conservation of energy to get the velocity of the pendulum immediately after the collision" because in a inelastic collision EK is not conserved.
You were given other information about the pendulum involving its energy...
Thats why I tried solving by... Ek(bullet) = Ep(pendulum) + EK(bullet)
Why doesn't that work ?
well, let's say that velocity of the pendulum immediately after the collision is [itex]v_2[/itex]. Now since the gravitational force is conservative, here, the total energy is
conserved and you can use conservation of energy to connect angle with this velocity and find [itex]v_2[/itex]. since the bullet is momentarily inside the pendulum, the KE of the bullet is NOT conserved. but if we take system as bullet + pendulum, then there are no
external forces in x direction. so we can still use conservation of linear momentum.
Yes I tried that 300(0.01) = 2.21(v'). But what do I do with that velocity.
I tried Ek(pendulum+bullet) = Ek + Ep yet got the wrong answer.
Is there something wrong with this ?
Because energy is not conserved over the collision. Before and after the collision it is, for both objects separately.
Momentum, on the other hand, is always conserved. What do you need to know about the pendulum in order to calculate its momentum immediately after the collision? What information do you have on hand that could tell you?
The bullet does not remain in the pendulum, and energy is not conserved over an inelastic collsion. Even so, there is other information available that will allow you to calculate the KE of the pendulum bob immediately after the collision. If you have its KE, what else can you find?
300(0.01) = 2.21(v'), is that correct for the velocity of the moment the bullet strikes the pendulum? And if it is i can find its KE, which can also lead to finding its height ?
But I already found its height using trig.
before the collision, you just have the momentum of the bullet. after the collision, you have the momentum of the bullet plus the momentum of the pendulum (immediately after). so equate the two... you can get the velocity of the pendulum immediately after using the energy conservation for the pendulum ONLY. use that value in the above momentum equation to get the velocity of the bullet after it passes through
No, in this case you should never consider the bullet and pendulum to be one object. It just passes through.
You're holding the wrong end of the stick here :smile: Start with the height that the pendulum reaches and work back to find its initial velocity.
So, I did Ek(bullet) = Ek(pendulum)<-- found velocity, I used this for the momentum of the pendulum.
then did P(bullet) = P(pendulum) + P(bullet). I didn't get the answer
AHHH, don't know who to listen to.
what answers you have got for the problem so far ?
For gneill. Ek(pendulum) = Ep(pendulum). Correct, and that will give me its intial velocity that turned into its height?
That is incorrect. The KE of the bullet is never equal to that of the pendulum. KE is not conserved over the collision. Forget mixing pendulum and bullet KE's.
Use the change in height of the pendulum to find its initial velocity.
Ek(pendulum) = Ep(pendulum), isn't thzat what i said ?
Yes.
because with that I am not mixing bullet with the pendulum, and there is a form of energy that did give the pendulum height, and that's its initial velocity.
  • #31
Yes.
  • #32
gneill said:
Because energy is not conserved over the collision. Before and after the collision it is, for both objects separately.?
Can you explain this please ?
  • #33
I got the answer though :D
  • #34
And what are some other possibilities of finding the initial velocity of the pendulum. why didnt 300(0.01) = (2.21)V' work? Because for a brief instant that the bullet does hit the block or the slight second its leaving the bullet is in the block, and momentum should be transferred no ?
  • #35
Before the collision the bullet has a constant KE assuming that there's no air friction.
After the collision the bullet has a constant KE assuming that there is no air friction.
Before collision the pendulum bob has zero velocity and a constant height, so its KE and PE are constant.
After collision the pendulum is moving in a conservative field (gravitation), so total energy is conserved.
10K
