A paradox in electromagnetic theory
The discussion centers on a paradox in electromagnetic theory regarding the mass of an electron derived from its electric field. Feynman's analysis reveals conflicting results: one method suggests the mass is m = (1/2)(e²/ac²), while another yields m = (2/3)(e²/ac²). Participants express skepticism about resolving these contradictions within classical electromagnetism, suggesting the need for a more comprehensive theory. They also highlight that many paradoxes stem from coordinate transformation errors and the limitations of modeling electrons as rigid spheres. The conversation emphasizes the complexity of electromagnetic mass and the ongoing debates within the field.
  • #51
Hurkyl said:
By measuring the forces on the test charges, we obtain the values for the electric and magnetic field. (And thus obtain the momentum density)
This would make sense if you believe that fields are some "material entities" which possesses momentum and energy independent on particles. So that in order to find the full momentum of a system of charged particles it is necessary to add the momentum of all particles and the field momentum.
I don't believe in this idea. I think that a theory of directly interacting charged particles and photons can be formulated without any involvement of electric and magnetic fields (as independent material entities having their own momentum and energy). I understand that this is a complete departure from classical electrodynamics as it was known for 150 years. I also understand that my project is very far from completion. However, it is also clear to me that Maxwell's electrodynamics has a number of nasty paradoxes, and that some new approaches would be needed if we want to solve these paradoxes.
Eugene.
  • #52
All I need for it to make sense is to believe there is something called a "field" that has values at points and a quantity called "momentum" that can be computed from the values of the field.
If that quantity called "momentum" is involved in a generalization of the law of conservation of momentum, then I would even argue the label "momentum" is an appropriate name for that quantity.
If everything I just mentioned can be computed by physical experiment, and their computed values behave according to some theory, then I would even argue that that theory is a good description of "reality".
Pseudoparadox. A paradox is a logical contradiction; merely being counterintuitive is not enough. And, of course, 'counterintuitive' is a highly subjective notion.
I think you're right. And I expect that if you can manage this, then you'll wind up with something closely resembling a sea of photons whose stress-energy obeys Maxwell's equations, and that interacts with charged particles via the Lorentz force.
  • #53
Just to expand on this "hidden momentum" business:
a basic example might be a (neutral) square solenoid standing in an (upward) electric field. Say you close a switch, allowing a battery to produce a clockwise electron current in the solenoid. The external field accelerates charges on one side, and decelerates them on the other side, with the consequence that the electrons at the bottom have a higher average velocity than on the top. This gives rise to a net sideways momentum.
It's called hidden because you wouldn't normally consider it, but nonetheless (since it is predicted by such a trivial exercise in relativistic mechanics) it hardly makes sense to deny it exists. You can certainly perform experiments to verify the assumptions of the derivation.
But does that mean conservation of momentum as a whole is violated when you close the switch? Not if you believe the produced fields also carry an exactly opposite momentum, as per classical electrodynamics.
  • #54
My problem with this is that electric and magnetic fields cannot be measured directly. Their momentum and energy are also non-measurable quantities. Experiments measure properties of particles. So, nothing will be lost if fields are excluded from the theory and only particles are left.
Note that measurements of the momentum, angular momentum, and energy of electromagnetic radiation do not contradict my above statements. It is more realistic to consider EM radiation as a collection of particles - photons, rather than continious electromagnetic fields. The inadequacy of the continuum field picture becomes obvious when one considers radiation of very low intensity, where individual photons can be distinguished.
Eugene.
  • #55
It is measurable. I can perform an experiment that determines the value of the electric field at a point. Therefore, the value of the electric field at that point is a measurable quantity, that was measured by experiment.
Could you describe an example of an experiment that directly measures anything at all, by your definition? Every physical property, even of particles, would appear to be indirect by such a strict measure. For example...
How do I measure the position of something? I fire electromagnetic radiation at it, which the thing scatters or absorbs in some fashion. The scattered radiation interacts electromagnetically with the cones and rods in my eye, and so forth.
How do I measure the weight of something? I construct a device in elastic equilibrium (which is moderated by electromagnetic forces), and measure its position. I position the object so that its only substantial interactions are gravitation attraction to the Earth and electromagnetic repulsion with my device. I then measure the new position of my device. I repeat this experiment with a standard object, whose weight I've defined to be a predetermined value, and I can calculate the weight of my object.
How do I measure the mass of something? I measure the weight as above, I do another experiment to measure the acceleration due to gravity, and combine the results.
Actually, something is lost; knowledge of the charge and current distributions does not determine the electromagnetic field. If you knew the mass, charge, position, velocity, and acceleration of every particle in the universe simultaneously, that is not sufficient to predict the future motion of particles.
This information needs to be reclaimed if you are going to attempt to reformulate classical EM.
You are forgetting diffraction. :-p
No, this yielded an inadequacy of the classical picture of mechanics. And to the best of my knowledge, the electromagnetic field strength tensor makes the passage to quantum electrodynamics essentially unchanged.
  • #56
I can agree with your argument. Both points of view are possible. Currently, there is no experimental way to prove or disprove the existence of fields. One can say that particles are bundles of fields, or one can say that there are no fields, simply particles interact with each other without intermediaries at a distance. At this point, the choice between these two alternatives is a matter of personal belief and philosophy rather than hard-core physics. However, I hope that it will be possible to conduct an experiment that will clearly distinguish these two possibilities.
Why not? In the classical (non-quantum) world it is sufficient. Note also that photons must be included in the list of particles.
No, I am not. Photons are massless, so quantum effects with photons are visible at macroscopic scale. Diffraction, interference, and other wave properties of light are simply manifestations of quantum properties of individual photons. It may sound strange that Grimaldi's diffraction, Newton's rings, and Young's double slit were first quantum experiments. But I think it is true.
Eugene.
  • #57
I recently found a wonderful website with hundreds of articles that cover all kinds of problems and paradoxes in classical electromagnetism.
http://puhep1.princeton.edu/~mcdonald/examples/EM/
Eugene.
