Is There an Age Problem in the LCDM Cosmological Model?
In summary, a recent paper has investigated the cosmic age problem in the Rh = ct Universe, which is a model that has been proposed as an alternative to the standard ΛCDM model. The paper uses observational data from extremely old Global Clusters and a quasar to test the age of the universe in this model. It finds that the Rh = ct Universe can accommodate five Global Clusters and the quasar at a redshift of z = 3.91, but other models such as ΛCDM cannot. However, this discrepancy may be due to uncertainties in the age estimates of these objects, and it does not present an age problem for the universe as a whole. Further observations and studies are needed to fully understand the relationship
wolram
Dearly Missed
4,446
558
From what i have read, right or wrong, there seems to be an universe (age) problem for modern cosmologists,
This is the best paper i have found on the subject.
http://arxiv.org/pdf/1402.6433v3.pdf
Abstract Many dark energy models fail to pass the cosmic age test. In this paper, we investigate the cosmic age problem associated with nine extremely old Global Clusters (GCs) and the old quasar APM 08279+5255 in the Rh = ct Universe. The age data of these oldest GCs in M31 is acquired from the Beijing-Arizona-TaiwanConnecticut system with up-to-date theoretical synthesis models. They have not been used to test the cosmic age problem in the Rh = ct Universe in previous literature. By evaluating the age of the Rh = ct Universe with the observational constraints from the type Ia supernovae and Hubble parameter, we find that the Rh = ct Universe can accommodate five GCs and the quasar APM 08279+5255 at redshift z = 3.91. But for other models, such as ΛCDM, interacting dark energy model, generalized Chaplygin gas model and holographic dark energy model, can not accommodate all GCs and the quasar APM 08279+5255. It is worthwhile to note that the age estimates of some GCs are controversial. So, unlike other cosmological models, the Rh = ct Universe can marginally solve the cosmic age problem, especially at high redshift
Are there any other factors that rule this paper out?
Space news on Phys.org
I honestly am skeptical of this entire approach. The errors on the ages of these sorts of objects are quite large, and riddled with systematic uncertainties. By comparison, the CMB is very clean experimentally, with little possibility of systematic errors distorting the age by too much.
So in essence they're trying to challenge the result of a clean, clear experiment with low error bars by using very dirty observations riddled with uncertainties that are difficult to account for. Unless there is a really strong discrepancy, there's just no reason to take this kind of claim seriously.
Yes, but as we have discussed recently here there are now many objects that seem to pose an age problem in the early universe.
We have been discussing this on these Forums since 2005:
[/PLAIN]
Is there an Age Problem in the Mainstream Model? (Oct 2005)
Cosmic age problem ? (Nov 2008)
Is There An Age Problem In The Early LCDM Model? (Jun 2010)
Massive galaxy cluster could upend theory of universe evolution, (Dec 2014)
and An Age Problem (again)? (Jan 2015)
Each time we have said there wasn't really a problem and subsequent observations at higher red shift would clear up the matter - but the problem has just continued to get worse. So we still wait and see!
Garth
Of course we have, because in a noisy data set rife with systematic uncertainties, you're guaranteed to get a significant number that look either older than our universe, or too old for a particular model of our universe.
A quasar with BH M ~1.2 × 1010M and has a luminosity of 4.29 ×1014L seen at z=6.30
and one ULASJ1120+0641 a quasar which hosts a black hole with a mass of 2×109M and has a luminosity of 6.3×1013L at z=7.085.
From An ultra-luminous quasar with a twelve-billion-solar-mass black hole at redshift 6.30
So far, roughly 40 quasars with redshifts greater than z= 6 have been discovered. Each quasar contains a black hole with a mass of one billion solar masses (109M)
Not on their own then, and quite difficult to explain.
Garth
Garth
Right. That's largely a puzzle of supermassive black hole growth rates (which is a difficult thing to model), and potentially of the specific matter power spectrum in the early universe. It's not an age problem.
Yes, the problem with SMBH growth being that these are right up against their Eddington limits and very bright.
A dark BH can form by direct collapse into its Schwarzschild radius, but a very luminous accretion disc is limited by radiation pressure and the BH takes time to form.
If there isn't enough time then you have an age problem.
As I said, it's a far, far messier physical system than the CMB. Because supermassive black holes are such complex objects (more accurately, the infalling matter is), it's vastly more likely that we're misunderstanding something about those black holes than it is we're misunderstanding the CMB.
So these types of studies are interesting, and may have an impact on cosmology (if the discrepancy comes, in part, from misunderstanding structure formation). But they do not present an age problem for our universe as a whole.
1. What is the LCDM model and how does it relate to the age of the universe?
The LCDM (Lambda Cold Dark Matter) model is a widely accepted cosmological model that explains the evolution of the universe. It predicts that the universe is expanding at an accelerating rate, and that this acceleration is caused by a mysterious force called dark energy. The age of the universe is a crucial aspect of this model, as it helps determine the rate of expansion and the amount of dark energy present.
2. What is the current estimate for the age of the universe according to the LCDM model?
The current estimate for the age of the universe according to the LCDM model is around 13.8 billion years. This estimate is based on various observations and measurements, including the cosmic microwave background radiation and the Hubble constant.
3. How does the age of the universe in the LCDM model compare to other cosmological models?
The age of the universe in the LCDM model is consistent with other cosmological models, and is supported by numerous observations and data. However, there are some alternative models that propose a younger or older age for the universe. These models are still being studied and debated among scientists.
4. What are some potential challenges to the age problem in the LCDM model?
One potential challenge to the age problem in the LCDM model is the Hubble tension, which is the discrepancy between the measurements of the Hubble constant from different methods. This can affect the estimate for the age of the universe and may require further study and adjustments to the model. Another challenge is the lack of a complete understanding of dark energy, which plays a crucial role in determining the age of the universe.
5. How does the age of the universe relate to the concept of the "big bang"?
The age of the universe is closely related to the theory of the "big bang", which states that the universe began as a hot and dense singularity and has been expanding ever since. The age of the universe is a key factor in determining the validity of this theory and has been confirmed by various observations such as the cosmic microwave background radiation and the expanding universe.
